Steering Rack Boot Replacement
Old Jan 21, 2014 | 04:51 AM
V_Xero's Avatar
Default Steering Rack Boot Replacement
I just replaced the steering rack boots on my 1997 Civic. I followed the advice from other forums and painted a line across the tie-rod, tie-rod locknut, and steering rack end. Then I counted the rotations of the tie-rod and tie-rod lock nut when removing them to be sure they would be put back on in the same place.
I almost gave up when I tried to put the new boot on, however. It's in a difficult to reach place and the end of the boot has to be stretched quite a bit to go over the steering rack. I ended up cutting a strip of plastic from a Kroger orange juice bottle about 4 1/2 " long by about 2" wide. There's no engineering to this size; it was just the size I could cut from the flat side of the square bottle. A liter Coke bottle would probably work better because you could cut around it. After sliding the boot onto the shaft, I placed one side of the plastic strip into the boot and the other over the steering rack, forming a funnel shape so I could slide the boot over the end of the rack. Then I took needlenose pliers and pulled the plastic out of the boot. Easy? No, I still had to pry and push with a screwdriver and pick at the plastic to get it out, but it did make it possible.
Old Jan 21, 2014 | 06:15 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Steering Rack Boot Replacement
pics
Old Jan 21, 2014 | 06:47 AM
Fishbone Fan's Avatar
I paid a garage $35 labor ($15 part) to replace the inner tie rod boot and was glad I chose not to do it myself.
yohimbine
Sep 12, 2013 08:49 PM
ge_ej1
May 17, 2008 07:41 PM
RanCRX
10
Oct 9, 2007 05:44 PM
NZDelsoldude
Dec 15, 2006 02:30 PM
DJ_SaNdOz
May 26, 2003 04:17 AM
