Fs: H22 swap for eg/dc with a ton of extras
David Heeter
Valdosta, Ga 31605 or Charleston, Sc 29404
Call or text for more info or pics
229-251-2676
I have my complete tuned h22 swap from my daily driven eg coupe (got rear ended a week ago and insurance totaled the car)
$2000 obo takes everything
Motor/trans
H22a4 complete untouched longblock (new timing belt 2500 miles ago, aem 2 intake, eBay header modded to 2.5 inch flange with v band, aem fuel rail, golden eagle egr delete)
Non LSD 5 speed trans, act clutch and flywheel
Swap parts
Eg/dc Mount kit, stock h22 prelude shifter and cables, Gator stage 2 axles, chipped vtec ecu tuned on chrome, Complete obd1 engine bay harness (converted injectors and distributor to obd1 so this is a 3 wire hookup in a eg/dc (starter, fuse box, and vtec)
Extras
H22a4 longblock I picked up to port the head and do a piston/rod shortblock
Skunk 2 intake manifold
Extra eBay header with 3 bolt flange
Slave cylinder with ss line to clutch master
Throttle cable for eg chassis
Aluminum radiator
A lot of misc h22 parts(manifolds plug wires, extra shifter cable etc)
Want $2000 for everything. Not looking to part out anything unless there is a buyer for the motor/trans first. If you have a car/ shell and are close I will help you do the swap or can install it for you for an extra $250. (Will need your car for 2-3 days). I can get more pics please text or call.
229-251-2676
Motor/trans
Swap parts
Extras
Aluminum radiator
