Want to Buy Want to Trade/Want to Buy
obd0/obd1 d16a1 or dohc zc parts
Old Jan 19, 2014 | 06:58 PM
digitalcongo's Avatar
Default obd0/obd1 d16a1 or dohc zc parts
picked up a g1 teg 86
need some rare hard to find parts to convert to obd1
still doing my research but i've got alot solved as far as information
thanks for any tips if you have ever converted a pre-obd vehicle to obd1
complete obd1 chassis/engine harness found - thanks rsxworld
obd1 jdm dohc zc intake manifold - found
will update, please check back
looking for ASAP:
solution for thermostat housing with coolant temp switch/sensor
i'm told one of the ek civic d-series housing works perfect
solution for alternator wiring - a couple wires need reversed maybe?
looking for future:
d15 block with intermediate shaft provisions (maybe the wagovan fwd d15b2 ???)
zc intermediate shaft
jdm d15b vtec crank
Old Jan 19, 2014 | 07:08 PM
TylerLorenz's Avatar
Default Re: obd0/obd1 d16a1 or dohc zc parts
Would you be interested in a Spare ECU?
Pm'd
Old Jan 19, 2014 | 07:11 PM
no i'm converting to obd1
thanks
Old Jan 20, 2014 | 07:39 AM
ZCHondaCRX91's Avatar
OBD0/OBD1 alternators are the same plug (OBD2 is different), I'm running a OBD0 A6 alternator on my OBD1 DOHC ZC.
Old Jan 20, 2014 | 08:51 AM
i've been out of the game just long enough to forget this stuff lol
thanks zchondacrx91
wait i believe i remember that two of the wires are reversed or something on obd0 alts?
also the teg is pre-obd .... obd0 was officially the 88/89 tegs afaik....mines an 86
so maybe there is chance the wiring for the alt changed
Old Jan 20, 2014 | 02:13 PM
thanks zchondacrx91
Good point, 86-87 use different alternators. The OBD0 (1988+) use the same plug as OBD1. I think the reversed wires are for the 86-87 integra harness (if you use that one) with a OBD0/1 alternator.
I converted a 87 integra to OBD1 a long time ago and don't remember much, but I will say take your time on the wiring. I actually changed the entire chassis/engine harness over, which took a long time but made it very clean with zero issues.
Old Jan 22, 2014 | 05:11 PM
why did they have to word this just dumb enough to make me think they could be the same
lol
like one is referring to is as from the harness side and one is plug side
i'm sure they need to be swapped, but thanks honda of america for having my back
D7_62
Classic Hondas
Aug 6, 2012 07:36 AM
brownsEF
Jun 14, 2009 03:29 PM
Angry
May 5, 2006 08:58 AM
Jmorin
Oct 16, 2003 07:06 AM
