b18B crank/b18c block plus B vtec engine parts
Old Jan 19, 2014 | 01:05 PM
$MIKE$'s Avatar
Default b18B crank/b18c block plus B vtec engine parts
couple thing im looking to get rid of.
pm questions
all prices reflect shipped price to 48 CONUS ( this is because I hate when you wanna buy something and someone gives oyu a bullshit price to ship)
Everything I ship is USPS tracked this is because they are cheaper than UPS and fedex by as much as 50%
trades welcome looking for SFWD intercooler
skinny 4x100
PNP pr3 head
hondata CPR
G force harness
please note I am not machine shop.
if my post is confusing then please pm me or text me.
205 three 82 78 four 7
b18B crankshaft was pulled form a running motor. all journals look good.
INCLUDED IS THE GEAR NUT AND KEY TO INSTALL THE CRANK PULLEY. THIS IS NOT ALWAYS THE CASE WHEN YOU BUY OTHER CRANKSHAFTS THEN YOU ARE SEARCHING FOR PARTS. $200 SHIPPED WITH ALL LISTED
ITR HARMONIC BALLANCER $40 WITH PURCHASE $60 WITHOUT
b18C1 BARE BLOCK (this mean the block and the caps and gridle with oem bolts manin seal plate thermo housing and water tube) this motor is stock bore or so im told but looks as such and measures right. I also have all the bolts for the attachments like water pump oil pump and most of the other stuff. this is so you don't have to spend $80 at Honda to get the bolts to put your block together.
could use a hone/line hone deck surface looks good will also come with a oil pump used but works good
$300shipped u pay fees
PR3 cam gears painted black $20 shipped
pcv box $25 shipped
used oil pump b18C it works $40 shipped
ITR crank pully harmonic $60 shipped 40 with crank
Old Jan 20, 2014 | 11:34 AM
$MIKE$'s Avatar
Default Re: b18B crank/b18c block plus B vtec engine parts
Ttt
Old Jan 20, 2014 | 05:31 PM
$MIKE$'s Avatar
Tt
Old Jan 21, 2014 | 03:10 PM
$MIKE$'s Avatar
Trt
Old Jan 21, 2014 | 05:10 PM
TeamRevHard's Avatar
Any grooves or scratches on gsr block? Does it look like it can be run as is or does it need a hone
Old Jan 21, 2014 | 05:33 PM
blackcherry's Avatar
You should at the least hone a block when you change the piston rings
$MIKE$'s Avatar
No groves I believe it can be run you can still see cross hatch.
I sprayed wd on the walls to store it and they look much better now.
But like I said I am not a machine shop or expert.
Old Jan 21, 2014 | 05:34 PM
$MIKE$'s Avatar
I can alway send details pics of each cylinder if your serious
Old Jan 22, 2014 | 02:16 PM
How are threads for headstuds and where the tranny mounts to?
Old Jan 22, 2014 | 02:49 PM
$MIKE$'s Avatar
100% good to go.
Old Jan 23, 2014 | 03:26 PM
$MIKE$'s Avatar
Ttt
Old Jan 24, 2014 | 03:05 AM
$MIKE$'s Avatar
Ttt
Old Jan 25, 2014 | 04:51 AM
$MIKE$'s Avatar
Ttt
Old Jan 25, 2014 | 08:12 AM
$MIKE$'s Avatar
Taking reasonable offers
Old Jan 26, 2014 | 04:02 AM
$MIKE$'s Avatar
Ttt
Old Jan 26, 2014 | 07:38 AM
$MIKE$'s Avatar
oil pan sold
Old Jan 26, 2014 | 03:43 PM
$MIKE$'s Avatar
tt
Old Jan 27, 2014 | 05:52 PM
$MIKE$'s Avatar
Ttt
Old Jan 29, 2014 | 08:49 AM
$MIKE$'s Avatar
tt updated
Old Jan 31, 2014 | 05:09 AM
$MIKE$'s Avatar
taking offers on all
Old Jan 31, 2014 | 06:16 PM
$MIKE$'s Avatar
Ttt
Old Feb 1, 2014 | 02:57 PM
$MIKE$'s Avatar
ttt
Old Feb 2, 2014 | 08:50 AM
$MIKE$'s Avatar
Tt
Old Feb 3, 2014 | 05:30 PM
$MIKE$'s Avatar
Ttt
Old Feb 6, 2014 | 06:03 PM
$MIKE$'s Avatar
Ttt
