LSVTEC96HB 1979 CVCC build
Old Jan 19, 2014 | 07:14 AM
LSVTEC96HB's Avatar
Default LSVTEC96HB 1979 CVCC build
Time for another project! I recently found this car and decided to rescue it. It was rusty, dented, barely ran, and was just generally neglected. In spite of all of its problems, I was able to drive it home in a big cloud of oil smoke and steam.
Day 1
Seriously, how cool is this interior!? I'm loving the wooden steering wheel.
The engine bay was full of wet leaves, dirt and 35 years of caked on motor oil.
She is a little smoky....
Epic smoke pouring out of my garage!!
Despite having a new carburetor, it still wouldn't run right.
I decided to try and buff out the hood a little bit to see what was under the faded orange paint.
There were some pretty serious rust holes. I started with the passenger side fender, cutting out and replacing the rotten metal:
Beating out the dents and first layer of body filler
I think the hood is too far gone to repair, but I tried anyway just for fun.
Some of the side molding pieces were missing so I decided to take them all off for a cleaner look
Much more to come on this one:
Major rust repair
Engine swap
Paint
Interior
Suspension
Wheels
Old Jan 19, 2014 | 10:45 AM
toyomatt84's Avatar
Sanji
Default Re: LSVTEC96HB 1979 CVCC build
This is going to be good. Best of luck on the new project.
Old Jan 19, 2014 | 11:06 AM
fremontcivic's Avatar
can't wait to see more...
Old Jan 22, 2014 | 01:51 PM
captaingamez's Avatar
this is totally sick.
Old Jan 24, 2014 | 10:06 AM
RotiEatter's Avatar
Ditto
Good luck. Looking forward to seeing this.
Old Jan 28, 2014 | 06:04 AM
LSVTEC96HB's Avatar
Thanks!!
More updates:
Stripping the engine bay
Big dent in the roof
I used last year's calendar to create a template LOL
Traced onto some new metal
Tacked into place
I still have to cut/modify the frame rails to fit the new engine. Stay tuned!
Old Jan 30, 2014 | 01:02 PM
andre3wap's Avatar
haha The love is a never ending saga... Good Job man
Old Feb 1, 2014 | 05:02 PM
bbarbulo's Avatar
will be watching this for sure!
Old Feb 2, 2014 | 12:58 PM
LSVTEC96HB's Avatar
I made some more progress this weekend:
Removed the stock cold air intake fitting and filled the hole
Scored a D16A6 from an '89 CRX SI at Pull a part this weekend. I'll be doing a refresh on it, cleaning it up and painting it, but not much else. It should still be a lot of fun to drive.
Painting the valve cover
Test fitting the new engine/transmission
Old Feb 2, 2014 | 03:50 PM
Tom_Chooch's Avatar
This is sweet! Love seeing unique builds like this, keep up the good work, definitely gonna follow this one
Old Feb 2, 2014 | 04:04 PM
cetcivic's Avatar
no one wants to hear the truth
Good luck w build
Old Feb 2, 2014 | 06:31 PM
pooby1992's Avatar
I may be able to offer something here. When I saw you were building a '79 I was very interested as I used to have a '75. When I saw you were putting an A6 in it I knew I had to comment, as my '75 had an A6 in it also, with a nitrous kit.
Here are a couple pics:
If you don't want these pics in your thread, I apologize. Let me know and I can delete them. Or, if you want to see more pics, let me know.
Old Feb 11, 2014 | 09:47 AM
LSVTEC96HB's Avatar
D series is definitely not a bolt-in!
passenger side frame rail
Driver side frame rail
I was originally planning to use a D16Y8 manifold but it's just too big.
Driver side frame cut out for clearance! I aint scared!!
Passenger side
Still need to cut some more to clear intake manifold
Aligning the motor and installing the stock motor mounts to locate and fabricate mounting brackets
Template for driver side motor mount bracket
The valve cover is the only part of the car that's finished
Back to the body work:
both front fenders were borderline beyond repair. I got my dad to bring his 40 year old hammer and dolly (seriously) along with his 40 years of body work experience to fix it.
Massaging the fenders back into shape
Dad pulling out the radiator support from where it was pushed back
The subframe was rusted out on both sides and needed some fresh metal
A lot of progress on the body, but still a long way to go.
New frame rails and motor mount brackets will be cut out of 3/16" steel plate
Old Feb 13, 2014 | 12:34 AM
ChaseIntegra's Avatar
Oh man! Nice project!!!
Old Feb 13, 2014 | 04:13 AM
Freemananana's Avatar
I love seeing these things. Any idea on the weight of the car? Definitely a beast when it's all said and done. Where do you buy your sheet metal? Price per sq/ft?
Old Feb 16, 2014 | 10:52 AM
LSVTEC96HB's Avatar
I'm guessing it will be a bit more than the stock 1500Lb. due to the extra weight of the engine/transmission.
I get all my metal from Freedom Metal in Charlotte. The 3/16 steel was about $80.
Old Feb 16, 2014 | 11:07 AM
LSVTEC96HB's Avatar
Thanks!!
The D16A6 I bought from the local pull a part ended up having a thrown rod... luckily they worked with me on a trade, I just had to find another engine.
I was torn between an 86 Integra D16A1 and a freshly dropped '91 hatch with a ZC swap. The Integra looked pretty beat, and clearly hadn't been maintained. The Civic was wrecked in the front, which is a good sign the engine was working when the car was junked. I pulled it yesterday and after getting it apart it looked really clean inside. Also, it has a MLS head gasket and a brand new clutch among other things. And, except for having to spend half a day wrenching it out of the car without power tools, ended up being a much better deal.
Old Feb 16, 2014 | 12:29 PM
r_Senik's Avatar
yes, any d series motor would be beast in this car.
Old Feb 16, 2014 | 03:14 PM
toobuzy4suicide's Avatar
Cool! good luck with you're build
Old Feb 17, 2014 | 06:42 AM
LSVTEC96HB's Avatar
Yeah I looked up the specs for the SOHC non-vtec ZC and it's rated at 118HP. I figure another 10 for I/H/E, plus it will be dyno tuned with NepTune at RLZ so guess around 110 at the wheels or so, in a 1500Lb car it should be reasonably quick. I'm running a 1989 CRX SI transmission too.
Old Feb 18, 2014 | 06:32 PM
LSVTEC96HB's Avatar
Thanks!
Time for a quick update:
I was contemplating replacing the old stock radiator with a plastic one from an EK, but I decided to repair and polish it up. I have to say it looks pretty cool!
Test fitting the first pieces of the new frame rails:
Old Mar 12, 2014 | 06:49 PM
LSVTEC96HB's Avatar
Tig welding the new frame rails
ZC motor almost ready to drop in
Old Mar 14, 2014 | 04:32 AM
mudko3's Avatar
What a stout project. Cant wait to see more, subbed.
Old Mar 14, 2014 | 12:16 PM
Riced-EL's Avatar
Sweet build!
Old Mar 14, 2014 | 07:23 PM
OG Wagon's Avatar
Very cool!
Keep it up.
