My wheel shakes at low speeds
Old Jan 19, 2014 | 05:59 AM
Papalou's Avatar
Default My steering wheel shakes at low speeds
My steering wheel started shaking recently at low speeds, less than 30mph, and after that that it doesn't shake but, the car seems to wobble a bit. Also when I turn the steering wheel all the way to the left to make a U-turn and accelerate too quickly it seems to make the car jump and its makes a loud squealing noise. I've checked for a loose wheel, all the ball joints are good and outer tie rods and control arms seem good. Could this be a bad inner tie rod or steering rack?
Old Jan 19, 2014 | 06:20 AM
slowDB7's Avatar
Default Re: My wheel shakes at low speeds
Have you checked your wheel bearings too
Old Jan 19, 2014 | 07:05 AM
accord2civic2prelude's Avatar
how much play is in the steering before the tires start to move
Old Jan 19, 2014 | 09:15 AM
Mr. Dabolina's Avatar
I had 2 bent wheels that made mine shake at low speeds.
Old Jan 19, 2014 | 10:01 AM
B_Swapped93's Avatar
check tie rods and ball joints, and that one of your lugs hasn't come loose more common then you think.
Old Jan 19, 2014 | 10:24 AM
NotARaCist's Avatar
I never narc'd on nobody!
It's also quite possible you've thrown a wheel weight.
Old Jan 19, 2014 | 10:39 AM
Papalou's Avatar
Guys, sorry for the confusion but, I meant steering wheel not the actual wheel. I recently drove it on the freeway and noticed there's about an 1 or so of play in the steering wheel before the car actually moves left or right. This is most likely my steering gear box right?
Old Jan 19, 2014 | 10:40 AM
Originally Posted by Papalou
guy sorry for the confusion but I meant steering wheel not wheel. I recently drove it on the freeway and notices there about an 1 or so of play in the steering wheel before the car actually moves left or right. This is most likely my steering gear box right?
steering rack adjustment needed or tie-rods(inner/outer) but by the sound of it tie rod ends.
swizz977
Dec 24, 2013 02:46 PM
lildragon'07
13
Jun 2, 2010 08:31 AM
95C0upe
18
Oct 28, 2008 06:30 PM
b18c1wes
Apr 4, 2007 08:23 AM
A Blue Lude
May 25, 2006 11:10 AM
