FS: B18C USDM Swap EK
I am selling the B18 that was in my DD until a few weeks ago. I took it out because my daily drive is 40 miles one way and 99% of it is highway. Everything was running well when I pulled it out. Asking $2000 OBO. Plus whatever it is for shipping. I am in Columbus, OH.
B18C5 USDM Short block 40000 miles *- Was New in Crate.
GSR Cylinder Head
ITR Camshafts
Ti Valve Retainers
Skunk 2 Intake manifold
Hytech knock off Header
B&M FPR
ARP Head Studs
Mobil 1 Oil throughout life (after Break in period)
odb2a to obd 1 conversion harness
GSR Trans
Comes with everything you need to do an EK swap
99-00 Si Rear Bracket
97 Del Sol VTEC AC Bracket (allows you to reuse D-series AC compressor on a B series Block)
99-00 Si Shifter Linkage
99-00 Si Half Shaft
99-00 Si Axles
Powersteering pump and brackets.
No Distributor**
No wiring harness, can supply VTEC wiring/plugs uncut for an EK.
GSR Cylinder Head
ITR Camshafts
Ti Valve Retainers
B&M FPR
ARP Head Studs
GSR Trans
99-00 Si Half Shaft
99-00 Si Axles
No Distributor**
ToTriggerHappy
11
Oct 13, 2010 02:48 PM
