Is there a B-series A/C bracket without compressor mounting provisions?
Old Jan 17, 2014 | 07:20 PM
Mr. Dabolina's Avatar
Default Is there a B-series A/C bracket without compressor mounting provisions?
The B16A2 in my Civic has the factory A/C bracket / torque mount bracket. I'm not running A/C in the car. The bracket on the engine has a few ears on it that I assume the compressor mounted to. They clutter up the front of the engine IMO.
Is there an A/C bracket I can get that doesn't have provisions for a compressor? Something from a base RS Integra or Type-R maybe? I know neither of those came with A/C standard so maybe the A/C bracket is different.
Google didnt help me out much besides some part numbers for the different A/C brackets. I couldn't find a good picture of anything to help me out.
Worst case Ill just take a sawzall and a grinder to the factory one.
Old Jan 18, 2014 | 03:11 AM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Is there a B-series A/C bracket without compressor mounting provisions?
If it doesn't have AC...just remove the bracket itself.
Old Jan 18, 2014 | 10:56 AM
Then I can't use my driver side torque mount...
Old Jan 18, 2014 | 04:37 PM
94EG8's Avatar
Seagull Management
No, there isn't. The closest you're going to get is a JDM ITR aluminum AC bracket, it still has the holes but it looks cleaner.
Old Jan 18, 2014 | 08:06 PM
Marvin1985's Avatar
You could remove it and use an engine damper instead. Stiffer mounts
AznXstazy
Sep 2, 2014 09:05 AM
chero112
Apr 24, 2011 10:22 PM
buster97
Apr 27, 2010 03:12 AM
96BlackHB
Jun 21, 2003 03:14 PM
NeXtLeVeL_TyPe_R
Nov 24, 2002 07:47 PM
