Battery Light
Old Jan 17, 2014 | 09:35 AM
Rttix1337's Avatar
Default Battery Light
After doing a lot of research and some repair, I still can not find the answer to why my Battery light keeps coming on in my 92 hatch.
I had the alternator replaced a while back, and had no issues, after a while the battery light would come and go, and flicker.
Today I replaced the battery and I still have the same issue. Before you say it could be the ALT. I had it tested along with the battery and was told the battery was the issue.
I can't see any faulty wires... Someone please help so I don't just cut the wire to the battery light
Old Jan 17, 2014 | 10:09 AM
Former User's Avatar
Default Re: Battery Light
A bad battery won't cause the charging system light in the cluster to turn on. Your car has a charging problem, which is typically the alternator.
Old Jan 17, 2014 | 11:19 AM
Jakester9500's Avatar
Do you have heavy corrosion in your terminal cables?
CRX baby
Jun 2, 2019 02:39 PM
Bad_dude
Jan 25, 2011 07:10 PM
meelow
Apr 29, 2010 09:35 PM
Vtecme92
Oct 10, 2005 07:18 PM
