Idle speed fluctuates after engine reaches temp
Old Jan 16, 2014 | 06:35 PM
AWD5560's Avatar
Default Idle speed fluctuates after engine reaches temp
I've a '97 Civic in which the engine fluctuates between fast idle and 800rpm after the engine reaches operating temperature. The engine speed does not fluctuate under steady driving speed. Furthermore, idle speed does not fluctuate when the AC compressor (and evaporator fan) is engaged.
I previously had an OBD code of P0117 but cleared that after I replaced the ECT sensor and thermostat. No other codes have appeared.
What could possible be failing?
Old Jan 16, 2014 | 06:48 PM
JoeBlue's Avatar
Default Re: Idle speed fluctuates after engine reaches temp
So did you bleed and bump the cooling system after refilling it?
Old Jan 18, 2014 | 09:41 AM
AWD5560's Avatar
Yes.
Old Jan 19, 2014 | 03:39 PM
AWD5560's Avatar
I fixed this by taking the IAC valve off and cleaning it. The valve was stuck from years of grime buildup.
beocop
Jul 2, 2017 05:19 AM
r berq
35
Mar 23, 2015 08:45 PM
Dekorum
Engine Management and Tuning
Apr 3, 2012 07:25 AM
