02 honda coupe misfire
Old Jan 16, 2014 | 06:06 PM
sheist42's Avatar
Default 02 honda coupe misfire
I have a 3rd cylinder misfire I changed spark plug wires spark plugs and cleaned out valve cap interior of all oil build up... Still a problem WHAT NOW...
Old Jan 16, 2014 | 07:17 PM
soLame's Avatar
Default Re: 02 honda coupe misfire
I have 98 honda accord that just started to misfire on cylinder 3.
Here is what I have done so far:
Checks performed:
1. Spark test using in-line spark tester
2. Moved the spark plug around from cylinder 3 to cylinder 1.
3. Moved fuel injector from cylinder 3 to cylinder 2
4. Checked EGR valve, harness voltage as well as 1+3 terminal 12V activation on the valve
5. Disconnected EGR valve, had no effect on misfire, yet threw EGR CEL code
6. Noid light checked injectors
7. PCV valve vacuum
8. Compression test, all cylinders were in 180-170 range
9. Checked spark plug wires resistance, all the same.
Replaced:
1. Spark plugs with NGK copper
2. OEM cap and rotor
3. NGK wires
4. Air filter
Old Jan 16, 2014 | 08:31 PM
holmesnmanny's Avatar
pull the egr valve connector...let it throw a code for egr system which will turn off the system...if the issue goes away, clean out the egr valve and ports
soLame
Jan 22, 2014 10:40 AM
sawright
Aug 20, 2013 01:46 AM
tom48
May 10, 2011 04:42 PM
utn
Honda Civic (2001 - 2005)
Dec 15, 2009 08:57 PM
crum
Oct 9, 2005 05:29 PM
