Motor mount bolts?!
So I wet to clean under my good a little bit today to see that my drivers side motor mount was a few millimeters away from hitting my cam gear...OUCH. So both the bolts on the L Shape bracket that bolts to the motor, are gone. No idea where they went but that's no bueno. I couldn't find anything on those bolts, but does anyone know the thread pitch and length of both of them? Or if their different lengths for the top and bottom? I really need this info I don't feel like blowing my DD's motor with a cam gear seizing on that bracket. Thanks guys.
Correction for anyone else who needs to know, the bolts that hold the L shaped bracket to the motor are 35mm long, and the threading is 10x1.25mm. You guy were right but those were the ones that hold the bracket to the mount.
Oh no dude it's cool you were right about the length, they were just the other set of bolts on that bracket haha. And thanks dave here I was about to go put some blue loctite on them. Dohy! Is the red high heat or something?
blue is light lock, red is akin to an anerobic sealant, meaning in a double machined surface such as gearbox halves. anything that does not use a gasket, but are machined in pairs to mate and contain lubricant. hope this helps.
regards
dave
regards
dave
jdmthug
May 19, 2008 08:32 PM
