97 civic sedan b18c starting swap.
Old Jan 14, 2014 | 06:27 AM
dupes4lyfe's Avatar
Default 97 civic sedan b18c starting swap.
hey guys this is my 1997 civic that has no problems at all except rear quarters, will be cut out this summer and welded on and painted for a pro finish.
right now i picked myself up a b18c block and building it up from there right now my builds looking like,
OEM bearings
Forged pistons 81.50 mm bore
OEM waterpump/timing belt
Skunk2 IM
Main stud bolts
mainly doing a daily driver build that will be also turboed by summer. will keep up too date on pictures and information from here on.
Old Jan 14, 2014 | 06:41 AM
dupes4lyfe's Avatar
Default Re: 97 civic sedan b18c starting swap.
this is the block im starting with already have the, its been bored over 0.50mm so now its 81.50, sending it too a machine shop for pistons in a week or two.
GSR head
Type r crank
GSR IM for sale actually.
Old Jan 14, 2014 | 07:02 AM
andre3wap's Avatar
nice man, Looking forward to see more updates.
Old Jan 14, 2014 | 09:41 AM
Bluto!'s Avatar
^^^^X2
Old Jan 17, 2014 | 09:33 PM
dupes4lyfe's Avatar
Got most of the build parts together just need a type r transmission and b series axles.
Old Jan 20, 2014 | 10:33 AM
dupes4lyfe's Avatar
dropped the crank / dissasembled head just valves/springs / block too be machined and etc for 100% fit, pistons put in then. then head back together reassemble the block and just need a type r lsd transmission. post pictures when items are back and building.
Old Feb 20, 2014 | 03:09 PM
dupes4lyfe's Avatar
Got the items back from the machine shop, crank/head/block all reaurfaced and reconditioned, got some mahle performance 9.5.1 pistons with mahle (cleveite) bearings a fel pro gasket set. Just need connecting rods
Old Feb 20, 2014 | 03:29 PM
slowDB7's Avatar
first thing i think you should do before the engine work, is remove that wing i see back there. otherwise it looks good
and in for updates
Old Feb 21, 2014 | 06:31 PM
dupes4lyfe's Avatar
Aha i love that wing i like the ricer look painting the car right now while building the engine also for after i have type r mud flaps too make it look more ricer aha.
My main question is i just need connecting rods whats a good brand too go with my build ? Wondering if i should keep the mahle build just get mahle rods.
thunderboy
Jul 13, 2010 09:38 AM
hndacord02
May 11, 2007 07:09 AM
b18bEKcoupe
May 28, 2006 07:27 PM
SEFIxCivic
Oct 9, 2003 06:52 PM
Vampyre
Apr 6, 2003 06:17 AM
