Good shop in LA that deals with k20/k24s. Need my k24 serviced!!
Old Jan 13, 2014 | 10:24 PM
Syper's Avatar
Default Good shop in LA that deals with k20/k24s. Need my k24 serviced!!
Looking for a good shop in LA that i can get my CRV serviced at. Have a p0341 code and want someone that knows what they're doing!!
Thanks
Old Jan 14, 2014 | 07:14 AM
spoonfed*ek9's Avatar
Default Re: Good shop in LA that deals with k20/k24s. Need my k24 serviced!!
Fast Autoworks
333 N 1st Ave, Arcadia, CA
(626) 447-6171
Old Jan 14, 2014 | 07:44 AM
aftermath1312's Avatar
That code is for the camshaft position sensor. There's a few things that can cause that code.
1. bad sensor
2. wiring problems.
3. stretch timing chain/loose chain
4. cam gear skip a teeth and its not in its correct location.
The reason why you get that code is because the crankshaft position sensor and the camshaft are not synchronize. One of them is off from specifications.
Old Jan 14, 2014 | 11:15 AM
Syper's Avatar
Originally Posted by aftermath1312
That code is for the camshaft position sensor. There's a few things that can cause that code. 1. bad sensor 2. wiring problems. 3. stretch timing chain/loose chain 4. cam gear skip a teeth and its not in its correct location. The reason why you get that code is because the crankshaft position sensor and the camshaft are not synchronize. One of them is off from specifications.
Yeah, i know. But don't really want to throw money at it until i find out what it is lol Also i don't want to mess around with the engine. Haven't messed around with k20s before and dont want to end up messing stuff up. Need someone that knows what they're looking for when the codes pops up. Lmk if you know a local shop or know someone that can get it checked out!
Old Jan 14, 2014 | 03:50 PM
joeybuilt's Avatar
Check Out . TwoStep Motorsports in South Gate
4421 Firestone Blvd
South Gate , CA
(323) 485-8551 - Ask for Henry
Check them out in Instagram too @twostepmotorsports
Old Jan 15, 2014 | 07:11 PM
ek9junky's Avatar
Try Honda if cash is no issue. Just don't let the service advisor rape you.
Old Jan 15, 2014 | 10:14 PM
efkilla's Avatar
hi speed motor sports in sylmar does good work
Old Jan 17, 2014 | 05:29 AM
low&slow's Avatar
4421 Firestone Blvd
South Gate , CA
Old Jan 17, 2014 | 06:12 PM
SP GARAGE's Avatar
Check out richiewerkz on Facebook or IG
Old Jan 19, 2014 | 08:49 AM
all_up_in_uranus's Avatar
If you don't mind a little drive, Joe and Gabe at Eastside Muffler up in Palmdale always did awesome work on my old hatch.
Old Jan 19, 2014 | 03:45 PM
Syper's Avatar
Lol more like alot of drive!
I'll try to check 2stepmotors out!!
Looking for something abit closer though. Close to the usc/downtown area.
C4st0r_Tr0y
Honda Civic (2001 - 2005)
Aug 12, 2018 08:08 AM
ralfspeed
Nov 17, 2009 07:11 PM
kizner
Jan 29, 2006 09:39 AM
