2 - "New" Kicker S12L7 2ohm Subs with Grills - $475
Selling 2 brand new Kicker L7 12" subs for a really low price. Too big for my car, so I would rather sell them. Included with purchase are the aluminum grills which retail for about $80 a pair. Subs retail for $375 a piece. These are brand new items still in OEM packaging. Please let me know if you have additional questions or require more pictures. You can text me directly at:
(305) 741-6301. I can deliver if your within the South Florida area, or shipped to you for a nominal fee.
Specs:
•BRAND NEW KICKER S12L7 L7 12" 1500 Watt Car Subwoofer
•1500 Watt MAX
•750 Watt RMS
•Sensitivity: 88.6dB
•Frequency Response: 20-100Hz
•Impedance: 2 Ohm
•Dual Voice Coil
•Square vs. Round: More cone area results in greater sound pressure produced by the woofer
•The massive motor structure of the L7 paired with KICKER's patented square-woofer technology provides extreme output capability
•Heat-sinking cast aluminum basket provides a strong motor foundation and maintains low temperatures during long-term operation
•Injection-molded SoloKon™ is Kicker most advanced cone design, adding targeted strength for reliable performance and accurate response
•Patented corner-ribbed, double-stitched Santoprene® surround provides durability at high excursion with uncompromised sound quality
•360° constant-contact back bracing adheres directly to every contour of the cone to maximize mechanical coupling of the motor, maintaining precise linear excursion while making the woofer as strong and responsive as possible
•Heavy-duty speaker leads are stitched and glued to the spider rolls for reliable performance when pushed to the limits
•Progressive-roll spider keeps stress away from the glue joint of the spider landing for long-lasting reliability
•Venting in the back-bracing of the cone and perimeter of the spider landing provides maximum air-flow to cool the voice-coil during operation
•Dual Voice Coils with high-temp copper windings handle extreme power levels for long durations without burning out
•T-cut top plate extends the magnetic field of the motor, adding balanced motor strength throughout the entire excursion path of the voice coil
•Solid-dome extended pole piece maintains precise voice-coil control and aids in heat dissipation
•Product Condition: BRAND NEW
•Part Number: 08S12L72
Specs:
•1500 Watt MAX
•750 Watt RMS
•Impedance: 2 Ohm
•Dual Voice Coil
ek9vboi2
Mar 13, 2006 12:09 PM
