Suspension & Brakes Theory, alignment, spring rates....
gsr brakes into 00 dx quick question
Old Jan 13, 2014 | 08:54 AM
racing_reject_001's Avatar
Icon2 gsr brakes into 00 dx quick question
i have looked and even found the page on here to explain most of this conversion but i still have a couple questions i can not find answers for and hope someone can help me out.
The car: 00 civic dx hatch
conversion: gsr front and rear brakes
my questions are im going to upgrade the master and booster, should i go all gsr or itr on the booster and master? and will my existing lines work and line up to them? also ill be going with steel braided lines where i can, do i get the gsr ss lines or the civic dx lines? if this matters mostly a daily but will be hitting a few track days this year.
Old Jan 13, 2014 | 09:46 AM
kyden's Avatar
Default Re: gsr brakes into 00 dx quick question
rs/ls/gsr all have the same brakes, just for the record.
you do not need to upgrade the booster on the civic. use a 98 RS master. if you want a 1" get one from any of the abs integras from 98-01. they all bolt up.
i'm not a fan of using integra knuckles on 96-00 civics.
use 99-00 si lines.
Old Jan 13, 2014 | 11:50 AM
yea i am aware of that and someone said i dont have to change the lines thats why im asking, and why arent you a fan?
Old Jan 13, 2014 | 01:59 PM
anyone else have insight on this? em1 prop? can i reuse my hardlines? and what steel braided lines do i use? integra or civic? and would it matter if i do not have abs?
Old Jan 14, 2014 | 02:06 AM
spAdam's Avatar
Loved
Community Favorite
Probably because integra/"eg" knuckles are slightly different geometry. If you hold them up next to each other you will see a height difference.
Old Jan 14, 2014 | 07:44 AM
cruizinmax's Avatar
On my car I used a integra brake booster and master. The lines bolted right up. Make sure and get the master that has the square reservoir. I think its 98+. I used the bigger master on the stock booster and the brakes felt like crap.
I also used civic si steel braided lines. The integra ones seemed too long.
Old Jan 14, 2014 | 08:12 AM
so would using my existing knuckles be better?
ill check into that thanks man and also thanks for the info on the ss lines just want to make sure i have everything right the first time.
how about the prop valve? just the em1?
Old Jan 14, 2014 | 08:56 AM
spAdam's Avatar
Loved
Community Favorite
You need Si or EX knuckles.
All 96-00 prop valves are the same afaik.
Old Jan 14, 2014 | 09:03 AM
kyden's Avatar
you have the same prop valve as an em1 on the car already.
Old Jan 15, 2014 | 06:01 AM
cruizinmax's Avatar
You don't NEED ex/si knuckles. Integra knuckles work just fine also. ;-)
The prop valve on the hatch is the same as the si.
NAlover
Suspension & Brakes
12
Oct 29, 2009 04:03 PM
C_Rock77
Sep 29, 2009 03:37 PM
splickitysplat
Mar 11, 2009 08:21 AM
gsr civic dx
Suspension & Brakes
Jan 22, 2005 08:13 PM
Charles B.
Jan 22, 2003 09:09 PM
