Head swap question
Okay so as of now I have a f22b2 in my 92 accord ex. I bought it like that and after it broke down I started to find stuff that the person just half assed. I didn't have a lot of sensors and vacuum hoses hooked up. And I'm still missing one as of now. So I'm curious as to if it's the stock ex harness and ecu. But my question is can I swap a f22a6 head, intake and exhaust mani. Onto my b2 block if so what would I need to fully do the swap. At help is much appreciated.
yes you can and treat it like an f22a block..
does the harness appear stock? if so they could be running an obd1 f22b2 which should have been plug and play for the most part.
is the cel on for the iabs? if not then you could have a POB ecu.
so like you said intake and exhaust mani and correct ecu if you want to run iabs which is a pt6 iirc.
You are also going to need the F22A power steering and alternator brackets.
Depending on how the swap was done you may need a few more things as well.
Could you post up some pics of the engine and the components in the engine bay?
stemiched
10
Aug 24, 2006 07:35 PM
