tires
He obviously wants to decrease gear ratios and sidewall height because he mentioned 195/55. 205/55 wont shorted gear ratios, so I suggested 205/50-15.
The correct size to go down to is 205/55/15.
Now I run 205/50/15 race tires to help overcome the LONG gearing on our cars, but for street use I use 205/55/15 or 195/60/15
Oh, obviously, thats why he stated that in the original post (or not)...ever think he might just want lower profile tires with a larger contact patch?
12345 care to explain why you are asking this question?
f20 bitch maybe you didn't notice the title of the site. it is called honda tech, which would mean that this is a tech related site. if it is a appearance type of question that 12345 is asking, then there is a forum for that (which gennady posted) otherwise it has no place in the accord forum.
:edit:
also refer to the guidelines
[Modified by CB7 Driver, 10:38 PM 10/29/2002]
:edit:
I think what malice is trying to say is that not every question has some deep technical meaning behind it..all he's trying to do is say "hey, maybe the kid wants to slam his car and the stock tires have too much sidewall" not well since he wants low pros it has to be to shorten gear ratios...low pros simply look better, is that so hard to grasp? dont read so far in to things, you'll live longer. Why would you want lower profile tires? And if you say to decrease sidewall flex for better handling, I will verbally bitch slap you.
i also agree that 12345 should explain why he wants different sized tires because yes, this is a technically oriented site but maybe, just maybe there is a chance that someone might stumble into the site and want a simple answer. No offense Nick, but you really cant regulate evry question that comes into the forum because there will be questions that don't necessarily pertain to the technically oriented nature of the forum. All i was trying to point out to wontbebeat is that before he assumes that the person obviously wants to change gear ratios, he should ask why he wants to change tire size. I really didnt think it would be such a big deal pointing out that 12345 might just want better looking tires.
I am the death of nonsense threads as well as "rice". Nothing escaped me. I find it all.
I am Supermang
its really up to you...dont listen to these other guys (above) they just like to nit-pick. With the information that you have given its really difficult for a third party to give advice. However, my advice is to go with 55 it'll aborb the street imperfections a little better, visually it'll look better (not as much gap), but you may be a little higher off the ground.
i want to know because i want to use a set of 95 accord ex rims on my 90 accord. the tires on them are 195/60. i just wanted something that didn't look like baloons. i just wanted to see if anyone knew what size i needed. i just want lower profile tires. i'm not trying to race this piece of **** or anything. it's a frickin accord.
[Modified by 12345, 1:06 AM 11/1/2002]
Any more cracks about newbies? And dont try to put this in my mouth. See ya around ********.
performance? haha! it's a frickin accord. i have an integra and a civic h/b for performance.
and you can fit 215's on those rims also, just finding the right one is the question
some I should have done but NOOOOOOOOOOOOOOOOOOOooooooooooooooooooooo lets modify the tubby accord then wonder why its so slow..........
I dont come into the civic/teg areas and knock on your shitboxes.. and yah i've owned a few of both.
so stay out my forum and give me the same courtesy.
you have a lot to learn about performance, I guarantee I will roll your hatch or integra on track, and no I don't have an H22 or built motor or NAWZ, just a bigger set of nuts
im gunna say this LOUD and CLEAR.
to each his own, I'll drink to that
