Honda CR-V & Element 2WD & 4WD Element & CR-V
Sway bars
Old Jan 12, 2014 | 10:51 AM
Dells's Avatar
Default Sway bars
I been on this crv forum for many years on and off but I've never really seen anyone talk about sway bars. I just looked up some information earlier this morning and found that crv sway bars are 12-13mm. I looked on eBay and found an aftermarket one by ultra that is 19mm. On another forum I've read that some folks installed itr ones 22-23mm by relocating the brackets. Any inputs ht?
Old Jan 12, 2014 | 07:47 PM
www.megameet.org's Avatar
Default Re: Sway bars
Check my build thread. I have lots of pics of the stuff Ive done. Only thing I dont have is a front lower frame bar, or a floor b pillar bar/harness bar
Old Jan 13, 2014 | 11:12 AM
kapoosh valve's Avatar
Addco makes one, it's 19mm I believe. Same diameter as Ultra, and about $100 less expensive.
http://www.summitracing.com/parts/aco-2011/overview/
I'd be interested to see more about the ITR bar, but worry a bit about subframe tearing like on civics and non-R integras.
Old Jan 14, 2014 | 07:56 AM
kiseliok's Avatar
I got the one from summit and although it's significantly thicker, it is not a direct fit.
The bracket holes did not line up right, and the bar itself was rubbing on the rear subframe. Required some moving and welding. :/
Old Jan 23, 2014 | 06:18 AM
That's odd, considering they sell it as a direct bolt on.
Old Jan 26, 2014 | 07:32 AM
PhilStubbs's Avatar
Hopefully more info comes up on this. I would really like a hefty swaybar on the rear of my crv.
ribal_gh
Mar 15, 2014 01:18 AM
stoneman78
15
Jul 31, 2012 07:56 PM
onsetofpurity
Suspension & Brakes
Jan 9, 2008 09:49 AM
jDMJeRk
Dec 29, 2003 10:18 PM
mamaboy
Nov 17, 2001 06:49 AM
