What the hell happened to my b16a?
Good people of Honda-Tech, I come to you with another over-my-head problem.
Last night, I was getting on the highway, and was pushing up to about 4k, when my car starts to sputter a bit, then backfires hard. I start to pull over and my engine shuts off.
No smoke. No CEL's.
I was able to start it up again, but it idles sporadically and wont go past about 3.5k, and also will turn off on me at idle.
I pulled out the plugs and theres no water or metal shavings in thh cylinders.
ADDITIONAL INFO:
Before this happened, I had a problem where after about 4k, my tach would jump around. I didn't pay it much attention, as my speedo also does not work, and I chalked up both the problems to a faulty cluster and planned on replacing it later. I now feel this is not the case.
I had also just performed a fresh oil change earlier that day, with mobil 1 full synthetic and a new filter.
JDM b16a, gsr cams, obd0 pr3 ecu, ys1 gsr transmission
Any help, ideas, or advice would be greatly appreciated.
No smoke. No CEL's.
ADDITIONAL INFO:
The car seems to be running fine today, with the exception of the tach bouncing post-4k. Im guessing that after the backfire/misfire, the ecu went to limp mode.
As for the distributor, I agree. I had seen something posted elsewhere where someone was having a similar tachometer problem, and a new dizzy fixed it.
Being obd0, do i need a obd0 dizzy? Or can a different one simply be re-wired with my current plug?
PINKS
10
Apr 5, 2007 06:47 PM
PINKS
Apr 5, 2007 02:40 AM
