Del Sol and Civic EG Fusebox pinout diagram
Does anyone have a good picture about the fusebox pinout?
I need know because of this: https://honda-tech.com/forums/showth...545&p=49432777
Which pin (geen plug on fusebox) is going where, basiclly i need to know what every little cable does, because the del sol hasnass and coupe hasnass from the gauge to the fusebox are not 100% the same (yes it fits but pinout is different).
So anyone knows where i can find a diagram with which cable is for what?
I did build my del sol cluster back in, but no rpm so it means that it doesn't have the right layout.
I have a spear connector here that should go in the plug (original coupe).
Just need to know how to convert the plug from del sol harnass to coupe.
or... does anyone know a forum where they know more advanced things?
Imagine what you could have found if you had read the FAQ's sticky.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/civic-del-sol-fuse-panel-printable-copies-fuse-diagrams-here-1966666/
https://honda-tech.com/forums/showthread.php?t=1966666
Wasn't my question clear enough?
Let me re-do-it for you.
I need to know, the green plug that is in the fusebox where every pin is going to
the diagram shows fuses, did i ask that??? NO
I understand English may not be your primary language, so I'm going to be as nice about this as possible.
Don't be a dickbag just because you don't get what you want.
Buy/borrow/download a factory service manual. They're readily available online. What you want covers a LOT of information in that book, and if it hasn't already been compiled, you need to do it yourself.
- When i replace all cables from the civic to del sol i will end up with a lot of extra things i dont have (like rear window, roof those things).
I have no support for my electric roof.
When i replace the fusebox from civic to del sol i will miss a few things.
And because this is a temponary option i would like to keep it as simple as possible.
1: For max 2/3 months i will have the Del Sol clustor in my dashboard
2: After 3 months i will have the S2000 AP1 clustor and that one can be connected to my original civic harness.
So i just want something (for now) to make at least rpm/kmh/fuel/lights working.
Those are all in the gauge (in both).
I can wait 3 moths, but than i cannot use my car at all
thanks, i will look into it
Well, i did run cables direct from the clustor to the green plug and my rpm is working, speed is working, i dont know about my break lights and stuff..
Anyway,m my blinkers are not working.. but the cables are correct.
And my interior harness is still not connected.. have a few plugs i cant use (will make a picture later)
Asmooh
Jan 31, 2014 04:32 AM
YellowCivic95
27
May 8, 2002 05:49 PM
