integra dash problems. (wiring)
Old Oct 28, 2002 | 01:46 PM
dfoxengr's Avatar
Default integra dash problems. (wiring)
have had the dash in the eg for about 2 months and have had troubles getting the 94-95 integra cluster harness from certain people. finally got the harness after months of waiting, and driving with no cluster at all, and when i changed the integra gray plug to the civic gray one (like the guy where i work that has done 12 conversions said), and everyone else does the only things that work are the: high beam light, battery light, and the cluster background light and dimmer switch. i am in desperate need of some help here, the guy i bought the car from had put an alarm in it and made a horn button somewhere else, it is possible he messed with some of the other wires, but i dont know which. the stock cluster and harness worked perfect as it is right now.
Old Oct 28, 2002 | 02:49 PM
dfoxengr's Avatar
Default Re: integra dash problems. (hybridvteceg)
bump
Old Oct 28, 2002 | 03:23 PM
racecarpete's Avatar
i would say start tracing his wiring, he might have snipped or crossed a few things, you do have the wiring diagram for the cluster right?
Old Oct 28, 2002 | 03:31 PM
dfoxengr's Avatar
Default Re: integra dash problems. (SilverCivic2k)
yeah the cluster wires are fine. just behind the fusebox, and his crappy alarm wiring might screw something up can something be misgrounded and mess it up?
Old Oct 28, 2002 | 08:56 PM
hybridtuner's Avatar
what year cluster, harness, car harness behind fuse box? I have a 97 teg and put a 95 car harness in it but used the 97 fuse box I had to change a few things. Just a thought that the obd1 and obd2 could be messing it up. I also had to change the dr side fender harness it has different plug config on the inside at the fire wall. Just a idea
Old Oct 29, 2002 | 06:51 PM
dfoxengr's Avatar
Default Re: integra dash problems. (hybridtuner)
every one that the guy at my work does uses a 92 civic behind the fuse box harness, 94 or 95 teg cluster harness, and cluster year doesnt matter, but i have a 97 or 98 cluster. which he uses too.
Old Nov 5, 2002 | 03:43 PM
dfoxengr's Avatar
help..
plsarestupid
Jun 30, 2011 05:33 AM
civicdust
May 2, 2007 10:09 AM
dopey88
Jun 15, 2006 08:21 AM
xCIVICx
May 4, 2005 07:24 PM
