Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
DIY: Crosstour license plate light bulb replacement
Old Jan 11, 2014 | 01:22 PM
tlarimer's Avatar
Default DIY: Crosstour license plate light bulb replacement
After doing a search and only coming up with threads stating you need to remove the interior trim panels to replace the rear license plate bulbs, I decided to to make this quick DIY showing how to replace them from the outside in 5 minutes.
First, use your finger or a screwdriver to gently pry the right side(drivers) towards the left side(passengers) and pull back, this will release the right side.
Gently pull the housing towards the back of the vehicle:
Rotate the housing until it pops free of the tailgate assembly:
Push the gray release tabs on the back of light socket to remove the outer lense, giving you access to the bulb:
Replace bulb and reverse directions.
Hopefully this helps somebody out.
Tim
OLi82
Jan 20, 2018 06:00 PM
Mfoehrkolb
Sep 9, 2013 10:38 PM
fergs96integra
Jun 5, 2013 03:32 AM
SUPABLUEV6
Dec 31, 2008 02:33 PM
Mr.Speed
May 1, 2005 12:19 PM
