Won't Start After Swap
Old Jan 10, 2014 | 02:31 PM
FeelTheBass's Avatar
Default Won't Start After Swap
I have a 96 civic cx hatchback, recently swapped in a b18b1. The battery was fried so i bought a new one, and i go to turn the key over (cluster lights up/fuel pump primes) and when i turn it to crank the engine there is no response. The only thing i noticed was the light for the A/C turned off when i tried to crank the engine. Please help! Much appreciated. Cheers
Update 1/12
Just swapped the TPS and MAP connecters because RonJ said they were switched, and also preformed CKF bypass trick. Reset the ecu, and looked at my CEL, which was only throwing a code for my IAT (wierd, because i dont have my o2 sensors plugged in yet). Then, fired up the motor and the revs shot up again. Looked at the CEL and now im throwing a code 7, which is for my TPS. Not sure what to do next
Old Jan 10, 2014 | 02:38 PM
rice a roni's Avatar
Any cel lights? Did you short anything resulting in blown fuses?
Old Jan 10, 2014 | 02:43 PM
Default Re: Won't Start After Swap
When i turn the key to (II) position, the CEL comes on and stays on but so do the battery and oil light, does this mean i have a CEL? How would i know if i shorted anything?
Old Jan 10, 2014 | 03:36 PM
Former User's Avatar
Check whether the clutch pedal rubber stopper fell out.
Also press the switch button in and check whether the engine will crank.
Old Jan 10, 2014 | 03:58 PM
@Ron
The rubber stopper that sits near the slave cylinder? Not quite sure.
Also, not sure what switch you're talking about either.
Old Jan 10, 2014 | 04:00 PM
The switch at the top of the clutch pedal (switch A) presses on a rubber stopper.
Old Jan 10, 2014 | 04:51 PM
Ok perfect so i put that back together, it cranks now. But, it turns on for a few seconds then dies, could this be that my throttle isn't open enough? i replaced the throttle cable while preforming the swap.
Old Jan 10, 2014 | 04:53 PM
Pull the CEL code.
Old Jan 10, 2014 | 04:54 PM
Tyler Dirden's Avatar
I am Jack's...
Does it have fuel pressure? I would spray starting fluid at the throtle body in short spurts after startup to see if you can keep it going. If yes, fuel pump/relay/issue possible culprit.
Old Jan 10, 2014 | 04:59 PM
I tried pulling the CEL earlier, I don't have a scanner but i do have a paper clip. I've never actually done this before, do I just jimmy it in there until it stays or what?
Old Jan 10, 2014 | 05:00 PM
Short the two terminals of the service connector any way you want. A paperclip is fine.
Old Jan 10, 2014 | 05:02 PM
Indeed. Short the two wires on the loose connector by the ecu. The cel light will start flashing.
Count the flashes. Long pauses is 10 quick ones are 1.
Old Jan 10, 2014 | 05:19 PM
Just pulled the CEL's, results are: 3, 10, 41, 54, 65
3 - Map Sensor
10 - IAT (Not plugged in, no intake)
41 - Primary O2 (Not plugged in)
54 - CKF (Haven't done this operation yet)
65 - Secondary O2 (Not plugged in)
All of these besides CEL 3 were expected, because I haven't taken care of them yet. I was just trying to see if my car would start and idle properly.
So is my MAP sensor faulty?
Old Jan 10, 2014 | 05:25 PM
Fix the CEL codes. To get the engine to start and run, start with the MAP and CKF codes. But why stop there? Just fix them all.
Originally Posted by FeelTheBass
3 - Map Sensor
This^ information REALLY should have been mentioned in the first post.
Old Jan 10, 2014 | 05:30 PM
So by throwing a CEL for my map sensor, does that mean that i should replace it? Any kind of test i can do? I don't know if this has anything to do with it but, when trying to crank the engine sometimes instead of idling for a few seconds then dying, it would just rev extremely high. Could this be from the MAP or a throttle issue?
Old Jan 10, 2014 | 05:33 PM
Reset the ECU and crank the engine for 30 seconds or until it runs. Then pull the codes again. Post them.
Old Jan 10, 2014 | 05:35 PM
I am Jack's...
High revs is almost always a big vac leak.
Old Jan 10, 2014 | 05:52 PM
Same codes, just did this.
Old Jan 10, 2014 | 05:54 PM
How did you reset the ECU?
Old Jan 10, 2014 | 06:06 PM
Took out the back-up 7.5A fuse from the under hood fuse box for 3 mins.
Old Jan 10, 2014 | 06:07 PM
What are the colors of the 3 wires in the MAP sensor connector? Posting a picture would be best.
Old Jan 10, 2014 | 06:16 PM
Yellow-Blue
Red-Black
Green-Black
Pretty sure thats what I saw.
Old Jan 10, 2014 | 06:19 PM
That's the TPS connector. You may have sensor connectors swapped.
What ECU?
Old Jan 10, 2014 | 06:25 PM
FML. Yeah I'll swap them and post results. Could this be the cause of the revs spiking when i start the car?
Obd2A p75
Old Jan 10, 2014 | 06:27 PM
Make sure that each sensor connector (wire colors) matches the sensor.
