Can I use a 1990-91 clutch setup in my 1989 ZC dohc motor and tranny???
Old Oct 28, 2002 | 01:31 PM
X's Avatar
X
Default Can I use a 1990-91 clutch setup in my 1989 ZC dohc motor and tranny???
Hey guys, I have a dilema that I need your help in...but first of all I would like say THANKS to those who responded to my previously posted driveaxle question.
I just removed my transmission and found out that both my ZC dohc motor and tranny is a 1989 model. (20 spline and 200mm clutch disc). I bought them as a set back in 1999.
Here is my question:
1. Can I use the 1990-91 Exedy organic clutch set on my car since it also has a
20 spline? I know the clutch disc is bigger, about 212mm.
2. Are the 89 and 90-91 stock flywheel the same or do I need to swap out my 89
flywheel to a 90-91 flywheel to compensate for the change.
The reason for this madness is because after some research, I found out something interesting (www.coximport.com):
-the Exedy organic clutch set for 1989 has a holding capacity of 29% over stock. Part #08-803
-the Exedy organic clutch set for 1990-91 has a holding capacity of 69% over stock. Part #08-801
I'm currently running a 1990 hb si- dohc ZC with anywhere from 50-70 shot setup. I have no plans for any future mods.
I would like to get this car back on the road, so your prompt reply is greatly appreciated...Thanks!
[Modified by X, 10:32 PM 10/28/2002]
Old Oct 28, 2002 | 10:29 PM
carsaregood's Avatar
Default Re: Can I use a 1990-91 clutch setup in my 1989 ZC dohc motor and tranny??? (X)
http://www.gamesbbs.com/~dmoore/tranny.htm
Check that out. The reason for the greater holding capacity of the 90-91 clutch kits is, i am assuming here, due to the larger contact surface area. 88 has a 190 mm flywheel/clutch disk, 89 size is 200mm, and 90-91 is 212. Get a 90-91 flywheel.. i have an extra one if you want to buy it off me for cheap. It came out of my '91 std. hatch.
Old Oct 30, 2002 | 09:58 AM
X's Avatar
X
carsaregood,
Thank you for the website, it helped...
As for the offer for your flywheel, just remember my car is a 90 si hb and I still have my stock motor and tranny, therefore I 'll just use that flywheel...thanks anyways.
So by your reply, I assume that all I have to do is swap out the current 89 flywheel with the 90-91 flywheel which in return will allow me to use the 90-91 1.6L civic clutch set.
Old Oct 30, 2002 | 10:02 AM
hahagasdcrx's Avatar
actually i think the spline count on the zc tranny if its an 89 is different so check your 90-91 clutch disk on the splines on the tranny if it doesnt fit you need to use the 89 one.
Old Oct 30, 2002 | 10:16 AM
X's Avatar
X
Default Re: Can I use a 1990-91 clutch setup in my 1989 ZC dohc motor and tranny??? (90crxzcgasd)
90crxzcgased,
As I recall, my 89 has 20 spline, and the 90-91 also has 20 spline. I think the 88 trannies are 21 spline.
So if the splines are correct, they should be interchangeble right?
I truly hope so, thanks...
Old Oct 30, 2002 | 12:42 PM
irtep's Avatar
you have to use everything from the 90-91. meaning flywheel, disk and pressure plate.
Old Oct 30, 2002 | 01:11 PM
X's Avatar
X
irtep,
Only three items for this conversion:
-90-91 flywheel
-90-91 clutch
-90-91 pressure plate.
Thank you... that's the confirmation I've been waiting to hear.
Creepshow S60
Nov 11, 2004 10:32 AM
phatrick2332
Mar 31, 2004 06:11 AM
Ronin Panda
15
May 11, 2003 05:05 PM
brusk
Jun 5, 2002 08:53 PM
