2006 ridgeline hood will not open in sub zero temps.
Old Jan 10, 2014 | 07:03 AM
rogr7066's Avatar
Default 2006 ridgeline hood will not open in sub zero temps.
My Honda 2006 ridgeline hood will not open because the gasket at the front of the hood is frozen to the fenders and grill. Anybody have a fix for this problem.
Old Jan 10, 2014 | 04:38 PM
TunerN00b's Avatar
Default Re: 2006 ridgeline hood will not open in sub zero temps.
When you live in an area subjected to sub-freezing temps, every fall you're supposed to lubricate (graphite or silicone grease) every single rubber gasket you intend to have opened during the winter (doors, windows, hood, trunk, etc...).
Having failed to do your proper maintenance, you need to melt the ice to get it open. Heat (blow dryer, heat gun, electric blanket, etc...) or chemical (ethanol, isopropyl, etc...) means will speed this up, or you can just wait with the vehicle in a warmed area.
Old Jan 10, 2014 | 07:21 PM
K24hb's Avatar
Get some deicer spray, or if you wanna take cheap route pour some hot water around seal
Old Feb 4, 2014 | 06:47 PM
j13's Avatar
j13
use silicone spray on all door, hood, trunk, window seals.
burnt_clutch
Jan 24, 2007 07:14 PM
AutoXer
16
Jun 11, 2006 11:39 PM
STYLiNxCHiQ_DA9
May 26, 2006 03:37 AM
Qikcivic
15
Feb 4, 2004 06:12 PM
01TypeR680
May 1, 2002 09:38 AM
