is this 92 civic corner light fixable
Corner lights are either around $20 on line. Or $20 bucks for a used oem set on craigslist. Dont be a cheap *** trying to fix broke inexpensive things or doing a ridiculous fix like above.
If you considera $75 part expensive, you might be in the wrong habit...
Also, you could pull ANY corner from a junkyard that doesn't have broken tabs, remove the back side, and insert your "mad tyte JDM y0" internals and lens on the junkyard back.
well i think the inner housing is different on the jdm corners im not sure but i was gonna swap lenses but the guy shipped me a sedan corner by accident so i cut the tab off do you think it will hold with some plastic weld i dont lol
