honda ef wont crank
the other day i was trying to fix my turn signals. car started fine before i messed with it but all i did was solder a wire for a better connection. but i did sorta pull the under the dash fuse box out for room. now it wont crank any areas i shoul look at. and thanks again.
does the fuel pump prime when switched to on ?
The main relay is in that area, and if it had cold solder joints you could have bumped it good enough to make it not work. Find it, and make sure its plugged into the harness securely, even if it is you should resolder the joints on it if you havent already.
its not too clear but if the only thing you messed with is the underdash fuse box, then you should double check if every multiple-pin connectors are still deep enough into it...
Ef4doorwagon
Apr 26, 2015 11:45 PM
srt4pilot
17
Jun 10, 2009 12:57 PM
