Questions on slicks
1 im running a 24.5 x 8 x 15 slick. would a smaller slick help me run a better time?
2 im running a 13.0 @106. im still spinning coming of the line an im running 8 psi in the slicks. thanks for your help
1. depends on your gears. you want to be at the top of fourth through the traps.
2. 24.5x8 should be plenty tire if you're only trapping 106. I'd look into dialing in your launch and suspension first.
turn down the launch limiter rpm and are you running full boost in 1st gear ? Is the head built? Can you get more rpm out of it so you don't have to shift to 4th gear?
A customer of mine ("sleepinonacreeper" here on Honda-Tech) runs 23" tires on his 600whp K20 Civic, and has no problem making 10.2-10.5 @ 138-140mph passes without over-powering the tire.
The only problem with running 23" tires on your car would be finding a tire for a 15" wheel in that size.
23"!
23"!
Yea I'm running full boost in 1st gear. Head is being built here directly and I can raise limiter a little more because I'm running it up to 7k right now.
Black R
Feb 2, 2002 12:29 PM
