Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
PO117 Code Question
Old Jan 8, 2014 | 04:32 PM
mytime's Avatar
Default PO117 Code Question
I am getting this code on my 07' Honda Pilot. It says Engine Coolant Temp Circuit Low Input. Is this the ECT sensor and where is that located on this engine?
Thanks,
Mac
Old Jan 11, 2014 | 06:14 AM
lazlong's Avatar
Default Re: PO117 Code Question
Look where the upper radiator hose meets the block. That's the thermostat assembly and the ECT should be sticking out of it.
Old Jan 26, 2014 | 12:47 PM
ricebike's Avatar
to add: check the wiring to that sensor ~ maybe a loose connection to that sensor can be the culprit/ clean/ reconnect/ clear the trouble code & see if the same code returns
you can also test the sensor itself while it's still screwed into your engine... ohm meter
resistance readings will be high when cold, then warm up the engine, unplug the wiring & see lower ohms afterwards
rudyndrew
Dec 30, 2010 02:12 PM
REDREXMANB16
Nov 23, 2006 09:54 PM
Rob!
13
Apr 13, 2003 12:01 PM
