hackjob underdash wiring help please
Old Jan 8, 2014 | 02:42 PM
crookson speed's Avatar
Default hackjob underdash wiring help please
ok so recently i was trying to find a short in my wiring to fix a front turn signal and i took my under the dash fuse box out to solder a better connection. and now my car wont crank but i also want to fix this hack job wiring this previous owner has done under my dash. i have no idea why he has done this but i know some of it is for the radio(which i took out). the car is a 1990 civic si with a b16a swap. keep in mind im a newbie and i dont know what to type into google or what im looking at but i want to learn so thanks for the help.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG]<a href="http://s1128.photobucket.com/user/greekrock/media/P1040710_zps34bb57dc.jpg.html" target="_blank"><img src="http://i1128.photobucket.com/albums/m492/greekrock/P1040710_zps34bb57dc.jpg" border="0" alt=" photo P1040710_zps34bb57dc.jpg"/></a>[/IMG]
[IMG][/IMG]
Old Jan 8, 2014 | 02:43 PM
Default Re: hackjob underdash wiring help please
and what is this relay in the engine bay for
Old Jan 8, 2014 | 03:18 PM
4drEF's Avatar
Keyboard Humorist
By the diagram on the relay, the relay is supposed to keep pin 30 (red wire) and 87a (the white wire) connected normally.
When power is applied to 85 (yellow) and 86 (orange) then 87a is supposed to disconnect and then 30 is supposed to connect to 87.
You have nothing connected to 87.
Basically this relay is being used to disconnect the red and white wire.
To know what this relay is actually doing, you need to figure out where that white wire is going off to and where the red wire is coming from.
My guess is that it might be alarm related.
Example - the alarm triggers and disconnects the red and white wire as a starter kill.
This makes sense to me because the relay is nearby to the starter.
What's not making sense is why the harness for the starter isn't cut into.
MAYBE the relay is being used to blink sidemarkers along with the turn signals? Do you have sidemarkers?
Old Jan 8, 2014 | 04:20 PM
this relay is conected to the stater switch if i just got rid of the relay and connected the cables to the normally it would work assuming everthing else is ok. i removed the side markers and there is no alarm.
Old Jan 8, 2014 | 04:21 PM
im going to post more pictures when there is light outside thanks
Old Jan 9, 2014 | 03:24 PM
DCRB's Avatar
possibly from an old alarm install? hard to say from such up close pics
Old Jan 9, 2014 | 04:09 PM
TikkiTimBro's Avatar
Hey man, I'm having a similar problem with one of my blinkers not blinking. I eliminated a bunch of stuff (grounds, sockets, blulbs and wires) I have yet to check for a faulty relay though. This could be part of the problem.
Have you made any headway with figuring it out?
smokincrxwannabe
Feb 8, 2008 04:25 PM
Quik S2K
Classic Hondas
Nov 18, 2007 04:34 PM
tek_civic
Apr 6, 2006 12:13 AM
