88 ef hatch shake high gear low rpm
Old Jan 7, 2014 | 11:24 PM
nonJDMefhatch's Avatar
Default 88 ef hatch shake high gear low rpm
I just bought this hatch (stick shift) first and second cant feel anything 3rd 4th 5th I can feel the front end shake and the higher gear and lower rpm the worse it is. Bit wen I hit speed in those gears theres nothing. It will slowly stop shaking, its not to the point where its gonna throw me off the road its just annoying and sketchy I want to fix it asap. All advice with be helpfull, all rudeness will be ignored keep comments to your self im here for help not attitude thanks in advance to any help.
P.s. the car is all stock lowered on lowering springs and has short shifter other then that bone stock. Idk wen the last tune up was done but i will be getting that done soon
Old Jan 8, 2014 | 05:44 AM
instrument's Avatar
Default Re: 88 ef hatch shake high gear low rpm
id start by checking motor mounts.
Old Jan 8, 2014 | 07:42 AM
The front motor mount does have a crack in the bushing. The side mounts look good from wat I seen ill get a second opinion. I have looked at the rear motor mount yet
Old Jan 12, 2014 | 07:27 PM
Update on my problem:
I was taking it on a better drive today just testing stuff out and if I get it to were it will start shaking if I turn the wheel either direction it will stop shaking, if im on the freeway and stop real fast it will shake for a sec any thoughts or experience you may have please let me know want to get this fixed asap thanks
Old Jan 12, 2014 | 10:16 PM
PoorManR_CRX's Avatar
Check ur axles
todubbled1
Jul 28, 2010 10:15 PM
02K20A2Ep3
Transmission & Drivetrain
Nov 30, 2009 10:03 AM
StolenTeg
Apr 27, 2008 02:56 PM
teh Dirka
Apr 15, 2008 03:28 AM
needashell1234now
Sep 24, 2006 09:06 PM
