Seized toe adjustment bolt problem!
Old Jan 7, 2014 | 04:57 PM
BrokenBone's Avatar
Default Seized toe adjustment bolt problem!
Hi all I went to replace my trailing arm bushings yesterday, I started by trying to remove the toe adjustment bolt when I loosened the bolt i noticed the bushing was twisting with the bolt despite that fact i continued to loosen the bolt. long story short I had to saw out the bushing and bolt, when i loosened the the bolt it pushed the frame(housing) out and now the bolt seems to short to screw back in..
Old Jan 7, 2014 | 05:09 PM
BrokenBone's Avatar
Default Re: Seized toe adjustment bolt problem!
what can i do to move that bar closer so i can screw in the bolt
Old pics before the the saw attack
Old Jan 8, 2014 | 07:23 AM
jlk16188's Avatar
mine did this, cut the bolt and pull the bushing out and remove the arm. Be careful you dont knock the nut off the back in the body. Its held in a track or lip and if it falls off you will have to cut a hole in the body to put it back on.
Buy a new bushing or arm with good bushings and another bolt and you'll be good to go. you will obviously need an alignment after
I like my R
Aug 24, 2023 08:56 PM
stevevang
Mar 27, 2016 04:46 AM
OneDirection
Suspension & Brakes
13
Jan 17, 2005 07:19 AM
LsNer00
Jun 29, 2004 12:09 PM
