Input Shaft Bearing. Which Puller?
Old Jan 7, 2014 | 09:24 AM
sengalang's Avatar
Default Input Shaft Bearing. Which Puller?
Like mostly every other tranny noise problem, my ISB is shot. Pulled the tranny, took it apart and the ISB inner race and its ball bearings fall out easily after taking out the shafts.
My question to those who has done this before, which bearing puller did you use? I live in a relatively small town and dont have the time to go out of town to buy one so I will be ordering it. (post links if possible)
Will it be a problem being just the outer race on the clutch housing to pull?
let me know if this makes any sense lol
Thanks
Old Jan 7, 2014 | 11:41 AM
Aquafina's Avatar
Default Re: Input Shaft Bearing. Which Puller?
Put the inner race and ball bearings back in, spread the bearings out and use whatever pull you can get. If there is an Autozone nearby they rent the puller (free once you return it).
Old Jan 17, 2014 | 07:05 AM
an2ny888's Avatar
can't you tap it out from the other side?
Nick97hatch
Transmission & Drivetrain
Jul 17, 2009 09:13 PM
ogmudbone
Feb 25, 2009 09:54 AM
XpL0d3r
Jul 27, 2008 09:35 PM
zman
Aug 22, 2004 08:41 AM
