Trip Odometer Stuck
Today I went to fill up gas and as usual when I finish I reset the trip odometer to see how many miles I get a tank. When I went to push it, the trip odometer got stuck, the numbers moved only a little and now the only one to move is the last digit on the right (white). Any ideas how to fix this, if it is even possible? Thanks
Cody
Cody
Ok so it seems to that all of the gears work, however the button to reset the trip gauge doesn't turn it back to zero. Can I replace the button? I know it is very similar to same year civics. Anyone with any information?
How cold is it? It might just be a case of frozen components. I have frozen issues too currently with buttons ect. You could always take the cluster apart and see what's wrong internally but that can be a pain and if you mess it up you risk ruining your cluster. I would recommend trying your skills on a spare cluster (any years ranging for 88-00 have basically the same mechanism). Good luck.
sf@rx7
Feb 17, 2006 07:42 PM
E36 Guy
Oct 3, 2005 05:32 PM
