1997 Civic Ex Skunk2 Intake/Throttle Body Issue - Please Help!?
Old Jan 6, 2014 | 03:57 PM
Hess97's Avatar
Default 1997 Civic Ex Skunk2 Intake/Throttle Body Issue - Please Help!?
Issue resolved. Please delete.
Old Jan 6, 2014 | 04:31 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: 1997 Civic Ex Skunk2 Intake/Throttle Body Issue - Please Help!?
Uh, how exactly does the stock TB not bolt up to the IM?
Your problem is the IACV. On the autotragic, the IACV is part of the throttle body. On the standard, it's part of the intake manifold. Junk2's TB doesn't have the holes for an IACV, so you would have to relocate it to the intake manifold.
Old Jan 6, 2014 | 05:42 PM
carlos8's Avatar
I don' know in d but for the b series, the new s2 manifold is now 70mm bore if you try to put a stock throttle the IACV passage stay inside the 70mm bore. Maybe is the same with D series manifold.
Old Jan 6, 2014 | 06:45 PM
NotARaCist's Avatar
The "hardware" part of it is relatively easy, it's the wiring that can trip some people up. Honestly, with your car being an automatic, I would just go ahead and return it. You won't see ANY power gains without a proper tune, and a proper tune would require converting to OBDI (usually easy), but would also be stupidly expensive for minimal gains. On top of that, being an automatic, your OBDI conversion would be a bit more...entertaining, to say the least, and Honda autos just can't handle any kind of added power past stock.
Old Jan 6, 2014 | 06:55 PM
NotARaCist's Avatar
Any bolt-ons for a D series motor, especially without a tune, aren't power adders, they're just noise adders.
Old Jan 7, 2014 | 07:11 AM
NotARaCist's Avatar
If you're talking about what I think you are, no, they don't do anything. And yes, I'm being honest about D series bolt-ons. If you want more power out of a D, you need to turbocharge, supercharge, or spray it, and those modifications will take your auto transmission and shatter it.
Old Jan 7, 2014 | 02:16 PM
Hess97's Avatar
Lol, thank you.
Civicek000
Oct 23, 2016 07:07 PM
elementwong
Sep 24, 2016 04:59 PM
stutler_jdm
May 14, 2011 09:05 PM
whiteboy-dc4
Sep 16, 2008 09:39 PM
