1992 Honda Prelude SI FUEL/TEMP issue
That fuse powers up the entire dash, clock, speedo, tac, exc.
Check power and gnd at the unit. If good, replace/repair unit
If anything, the board has the same dry solder issues that other components have on these cars, like the main relay and hvac control unit. If the wiring is ok to the unit, just replace it, should be plentifull at wreckers.
such a common problem with 4th gens that I just went aftermarket once mine died. prosport makes a decent temp gauge for how cheap it is, the fuel gauge I bought was awful though.
hotcoffey28
Jul 10, 2008 10:41 AM
