FS: 96 Civic b16A converted SIRII/SI, new paint, tucked and shaved bay
NEW PRICE $4700
The date on the paper is a day old because I didnt get to making this ad yesterday.
A few short months ago I bought this civic off another user on here in Central Florida. The car is very solid and only needed some finishing touches to clean it up, which I have done for the most part. Unfortunately my wife has moved back to part time work so I can't justify the toy vehicle.
Good:
- several new parts from honda such as window moldings, roof moldings, miscellaneous clips, etc.
- I had the entire car repainted OEM black, and she is BEAUTIFUL!
- Also, one of the axles started to go so I replaced both sides along with fresh Honda MTF in the tranny.
-The whole car is extremely solid. Pulls hard all the way to 8600, sounds great, and SO MANY brand new parts. PO did things the right way on this car. I just took it for a spin yesterday and it's a blast. I wish I could spend more time in it, but it's just not practical enough right now for my circumstances.
Bad:
- Needs an alignment
- Wipers not installed (though everything is there and comes with the wipers and even some new blades!)
Here is his original listing (before repaint):
http://hondamarketplace.com/showthre...&highlight=SiR
Miles:
The car actually has about 200k on it according to Carfax, but it is in fantastic shape. The engine is a fresh swap and is practically new.
I dont know the exact mileage because it has a jdm cluster and the miles on the title are exempt.
SUSPENSION
brand new (less then 400 miles on everything) skunk2 pro c full dampeners
skunk2 pro series front camber kit
skunk2 rear camber kit
omni control arms
brand new oem honda rear trailer arm and drums
brand new oem front calipers
stoptech rotors
russell stainless steal brakelines fr/rr
new oem wheel studs all around
brand new og axis wheels 15x8 +25 brand new federal 595 195 45 15 tires
muteki wheel locks/ and bulldog wheel lock.
ENGINE
b16a4 from H motors 30km
canadian b16 tranny 4.7 final drive.
Edlebroke victor x manifold
hondata intake manifold gasket
skunk2 pro series 64mm throttle body
aem fuel rail
aem FPR
aem fuel filter
B&M fuel gauge
stainless steel russell fuel lines and cooling lines
skunk2 cam gears
oem ITR valve cover
sr racing brake and clutch fluid covers
oem itr oil cap
koyo radiator
FAL fan and shroud
SPOON spark plug wires
SPOON radiator hoses
DC 4-1 header
plm test pipe
full apexi WS2 catback exhaust
act hdss clutch kit
act pro lite flywheel
Greddy timing belt
gates alternator belt
unorthadox crank pulley and alternator pulley
brand new oem bolts every single 10mm bolt
brand new trans bolts every bolt from honda
HASPORT solid motor mounts
ITR shift linkage
russel stainless steal clutch line
brand new iac valve
brand new slave cylinder
brand new battery
brand new harness wire tucked
jdm p30 street tuned. launch control, shift light, 8600rpm redline
walbro 255 fuel pump
js racing intake
bay is shaved and sprayed
brand new oem gas tank
BODY
brand new purchased from honda 00 civic front end
brand new oem si grille painted oem black
brand new oem si lip painted oem black
shaved side moldings
brand new rear deck lid
99-00 tailights
brand new rear bumper
brand new gas lid
pwjdm foglights
sir2 headlights
interior
brand new door panels
pwjdm carbon kelvar airbag delete
radio delete
brand new window regulators
SIR2 gauge cluster
4700. Quickest way to get in touch with me will be through text: 910.835.6263
Price Drop: $4700 OBO
Trades: I will entertain trades for CRV's, Subaru wagons, Foresters, or mostly stock GTI's.
Engine bay: (Pre-paint)
More Pictures! http://s955.photobucket.com/user/Kwa...ary/96%20Civic
Good:
Bad:
Miles:
SUSPENSION
omni control arms
stoptech rotors
ENGINE
aem fuel rail
aem FPR
aem fuel filter
B&M fuel gauge
skunk2 cam gears
oem ITR valve cover
oem itr oil cap
koyo radiator
FAL fan and shroud
DC 4-1 header
plm test pipe
act hdss clutch kit
Greddy timing belt
ITR shift linkage
brand new iac valve
brand new battery
js racing intake
BODY
99-00 tailights
brand new gas lid
pwjdm foglights
sir2 headlights
interior
radio delete
SIR2 gauge cluster
very nice car. is it an EX, LX, etc? were the ABS brakes retained in the engine bay wire tuck? Any Dyno #'s ?
Also - where are you in FL?
EX, no ABS, previous owner told me 177 whp, but I don't have a chart to prove it to you.
I'm in Central Florida - Orlando area.
kwalitee
Feb 15, 2014 04:59 AM
harajuka
Oct 22, 2006 12:59 PM
HondaRcB
Mid-Atlantic (Sales)
Oct 8, 2005 05:41 PM
