Missing at Low RPM
Old Jan 6, 2014 | 03:27 AM
afnan's Avatar
Default Missing at Low RPM
F18 B VTEC. I am kind of pissed of by the fact that no one can identify the problem even the big dudes in market.
Symptoms
1. Missing before 2k RPM not all the way but at some points.
2. If you drive the car once at throttle floored the car would badly and would require some slow driving.
3. Flat Spot after 4.5K RPM
What I have done:
Changed Injector (with their small filters)
Changed Fuel Pressure Regulator
Changed Ignition Coil
Changed ICM
Checked Spark Plug Wires for arc
Cleaned and sealed throttle body
Checked MAP and TPS
Changed Rotor
Checked Distributor Cap its fine
Mechanics say the fuel that returns to Tank has sufficient Pressure. They never used Gauge because no one does here. They inserted a pipe with FPR and into transparent bottle.
I saw continuous stream of bubbles in the fuel that exited from rail.
This is ODB2B car so it does not have timing adjustment. However i plan to check if timing belt is slipped or not.
I have googled enough and since past week I have been seeking solution to this problem. Please help me.
Thanks
Old Jan 6, 2014 | 03:46 AM
tealbubble's Avatar
Default Re: Missing at Low RPM
If your replacing ignition coil and icm you should go all the way and replace the inexpensive stuff. cap, rotor, wires, plugs. For a long shot you may have a clogged catalytic convertor. I've seen it happen before. If you unbolt it and the car runs better its a sure thing.
Old Jan 6, 2014 | 05:42 AM
afnan's Avatar
I would try unbolting the Exhaust tomorrow.
Old Jan 6, 2014 | 04:55 PM
MAD_MIKE's Avatar
MM Gruppe B
If the spark plug wires are old, or even if they are new, it doesn't mean they are flawless. Had a set of new NGK wires with one wire that had a small slit in in it that was unnoticeable.
Old Jan 6, 2014 | 08:30 PM
afnan's Avatar
What about bubbles in duel stream are they normal
Old Jan 7, 2014 | 01:56 AM
afnan's Avatar
Went to Shop Tested Fuel Pressure.
25 Psi on Idle with Fuel Pressure Regulator vacuum Attached
40 PSI with Fuel Pressure Regulator Vacuum Removed
Following are the test results from Scanner
I would be adjusting the TPS.
I am not sure about O2 m Fuel Trims and Spark Advance Values. Can you verify
afnan
Jan 5, 2014 03:57 AM
hostile1
Aug 1, 2008 06:57 PM
dgreenwud
Nov 16, 2003 04:29 PM
civicspeed77
May 27, 2003 12:13 PM
Greyout
Sep 15, 2002 03:01 PM
