H22 basemap
Old Jan 5, 2014 | 10:45 PM
Cho0se's Avatar
Default H22 basemap
Hello, can someone send me or advice me where to find good basemap for my setup? I need safely drive to my tuner - 50 miles. Im using crome free, P30 ECU.
H22
95mm stroke
12,5:1 CR
Skunk2 Pro1
70mm TB
550cc RC injectors
E85
Thank you very much.
Josef
Old Jan 6, 2014 | 08:52 AM
snobordboy's Avatar
Moderator
Default Re: H22 basemap
I would ask your tuner to set that up for you, then they have what you are starting with, and can go from there.
Honestly I would say just tow it the 50 miles for peace of mind. Also, from my experience with a fairly similar setup, I would say to try and switch to some ID or FIC injectors, they are awesome compared to the older style injectors on the market. I am running the ID1000 on my engine, and I am just on pump gas, not E85.
Old Jan 6, 2014 | 10:09 AM
Cho0se's Avatar
Do you think that RC injectors are bad or small?
It's a long story with my tuner. I hope that someone have basemap for similar setup.
Old Jan 6, 2014 | 10:23 AM
spoolinlude's Avatar
I live under a rock
I agree, your tuner should give you a basemap. If they can't provide a basemap I would switch tuners.
I would also tow it, basemaps are really just to make sure the car runs and nothing leaks. I wouldn't drive 5 miles let alone 50.....
Every setup is different. You could probably putt along those 50 miles and make it, but why risk your built motor for a $100 tow?
Old Jan 6, 2014 | 03:43 PM
snobordboy's Avatar
Moderator
RC are just an older technology. The new injectors are just that much better. Honestly I feel that my engine idles smoother with the 1000cc ID injectors than it did on stock 245cc injectors, and since I tried a set of Precisions before, and they were a pain to tune, and the IDs were so stable and easy to deal with when I swapped.
Check out the video of a stock 1.8 liter integra with ID2000cc on youtube. Also numerous other makes are using ID 1000 and 2000 as their go-to upgrade on 2 liter engines i.e. Subaru and Mitsubishi guys. Once I have the time to get my WRX back on the dyno, it will be getting a set of IDs as well.
Old Jan 6, 2014 | 07:55 PM
integra_101's Avatar
teknotik.com can help you out
thatguyjade
Jun 28, 2018 11:11 AM
Cho0se
Engine Management and Tuning
Jan 5, 2014 02:05 PM
DA is best
May 7, 2012 10:32 PM
tr0n9h
Nov 29, 2009 08:51 PM
Max_lude
Dec 15, 2003 08:57 AM
