Transmission & Drivetrain Gearboxes, Differentials, Clutches
Countershaft snap ring - remove/replace
Old Jan 5, 2014 | 03:59 PM
h22a_black's Avatar
Default Countershaft snap ring - remove/replace
Hey guys, does anyone have any tips on removing the countershaft snap ring from the case? My rebuild kit has a new snap ring, and I'd like to replace it but I cant seem to get the damn thing out. This is an h series case, if it makes a difference. TIA
Old Jan 6, 2014 | 11:42 AM
Aquafina's Avatar
Default Re: Countershaft snap ring - remove/replace
Vice grips to remove it. Your fingers to install the new one.
Old Oct 3, 2020 | 08:19 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Is this also true for D series?
And is this also true for B series?
And does the K series have a snap ring, if it does, does it apply to the K series?
As generalized as the topic, I think it wise to have all the answers in this thread as this is the only thread I find regarding re and re of the snap ring.
Old Oct 4, 2020 | 08:03 PM
Chrisfrom1986's Avatar
Read the rebuild thread instead of bumping a 6 year old one. Use snap ring pliers.
https://honda-tech.com/forums/transm...orial-2443459/
Old Oct 5, 2020 | 05:26 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
@Chrisfrom1986 I have read that rebuild thread a few times. It doesn't talk about removing the snap ring and replacing it in the transmission housing. You didn't understand the question. This 6 year old thread is the only thread I found mention of actually pulling the snap ring out of the case and putting a new snap ring back in. You know, the snap ring, not the counter shaft.
My question is quite relevant as this thread states it's quite doable on an H series with vice grips. Is this the same technique for all Honda Manual Transmission cases. Does the K series even have a snap ring in the case. Is the snap ring replaceable in the K series if it has it? Etc.
Maybe now you'll understand what is being asked and can answer from your experience or leave it to those who can.
Old Oct 5, 2020 | 08:22 AM
Aquafina's Avatar
Yes. All Honda transmissions use a snap ring and it can be removed with vice grips in all of them. I use needle nose vice grips to remove it.
Old Oct 5, 2020 | 09:40 AM
Replacing the snap ring is not necessary unless it has been damaged. At that point I would consider whether the transmission should even be used. In short don't worry about it.
Old Oct 5, 2020 | 09:19 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Thank you, your answer completes this thread so all searchers will have an answer regardless of which model Honda manual transmission they are working on. It obviously don't come up often, but it does once in awhile. Our repository is now complete on this topic. Cheers.
If the damage was done during the rebuild, the case and everything else is fine, why would you scrap the hundreds of dollars you've already put into the transmission and not replace the 8 dollar snap ring?
giff74
Mar 19, 2005 02:09 AM
ricerocket2nv
Jul 6, 2003 12:14 PM
