bad CV joint ???
Old Oct 28, 2002 | 11:54 AM
BlackCRX's Avatar
Default bad CV joint ???
i was wondering if i had a bad CV joint
this morning i went to kinda hard off the light and i hear a light clunking noise from the front passanger side
then i did some heavy braking to see if i heard it agian and the wheel sounded like it was kinda shaking
when i got to work i turned the wheels out and get a quick look and the both sides have new CV boots but i also noticed that the front passanger side tire was missing the wheel weight
so i cranked it all the way to one side and took off to see if i heard the noise agian but no noise
then i tried to reverse with the wheel still cranked and no noise
these are the only basic check i know how to do with out actaully remving the wheel and CV boot, is there any other checks i can to ??
do i have a bad CV joint or is it all due to my tire missing the wheel weight ??
edit: how hard is it to change a CV joint
if its the CV joint i plan to change both fronts but should i change the rear ones to or no ??
[Modified by BlackCRX, 12:55 PM 10/28/2002]
Old Oct 28, 2002 | 12:05 PM
BlackCRX's Avatar
Default Re: bad CV joint ??? (BlackCRX)
oh ya the car has about 200,000kms on it and its lowered on H&R race with KYB AGX if that makes a difference
Old Oct 28, 2002 | 12:47 PM
No More Civic's Avatar
Well, if it is a CV joint then you'll hear the noise when the car is in motion and you're turning. So, take a drive and turn both left and right to see if you can hear the noise again. Also, it usually makes a clicking noise.
Old Oct 28, 2002 | 02:12 PM
Hcivic88's Avatar
Default Re: bad CV joint ??? (SlowCivicDX)
if it only does it turning one direction it could be a cv joint.
also, just a thought, could it be a motor mount, cause if it was the motor could be shifting and making that clunking noise.
Old Oct 28, 2002 | 04:19 PM
BlackCRX's Avatar
Default Re: bad CV joint ??? (Hcivic88)
thanx guys
ill take a look at it on the weekend
jkalex05
Nov 23, 2009 06:52 PM
Secret Chimp
Feb 9, 2008 01:27 PM
dc2doi
Oct 15, 2007 11:23 AM
Acura97GSR
May 19, 2002 03:00 PM
JDubya
May 1, 2002 02:40 PM
