Will this work? Rear disc set up from a 94 Integra
Old Jan 5, 2014 | 11:29 AM
TNight's Avatar
Default Will this work? Rear disc set up from a 94 Integra
I have the rear disc set up from a 94 Integra and I wanted to swap it on to a 89 CRX. Anyone tried this or know what I'm up against?
Old Jan 5, 2014 | 11:41 AM
two81's's Avatar
Default Re: Will this work?
I have the same for my 91 hatch. I think you need the e brake cables as well. Not quiet sure, anyone else
Old Jan 5, 2014 | 06:13 PM
TNight's Avatar
It was a clean pull all lines ,cables, even the abs stuff is attached and ready if necessary.
Old Jan 7, 2014 | 02:25 AM
DCRB's Avatar
Default Re: Will this work? Rear disc set up from a 94 Integra
search function must be broken again... dang it...
yes they bolt right up, you'll need crx si ebrake cables and a 4040 prop valve from a non abs da for the brakes to work right
Old Jan 7, 2014 | 08:40 AM
hatcht9x's Avatar
^x2
and the golden rule back in the day was: retain the CRX arms (upper, lower, and compensator arms), and and bold the Integra trailing arms to them for alignment purposes.
Old Jan 7, 2014 | 09:01 AM
24TEN's Avatar
PHANTOM MENACE
X2 on the golden rule. CRX cables are ideal for a CRX but I'd also add that since it's going ONTO a CRX you can get away with any 88-00 Civic/90-01 Integra rear disc specific ebrake cables but you'll have a certain amount of extra slack. Going the other way (CRX cables on a Civic/Integra) is what you want to avoid because the CRX cables are shorter.
Old Jan 13, 2014 | 07:20 PM
TNight's Avatar
Thanks
Old Jan 13, 2014 | 07:28 PM
TNight's Avatar
Thanks
EfSedanLove
Nov 7, 2006 06:40 PM
Sean-Ratchford
Feb 25, 2005 04:44 PM
BOSS-REX
15
Oct 2, 2004 03:56 PM
CRXTC
Jul 10, 2004 06:45 AM
