Tuning 3 Civics - hope some will be very generous with map ski files
Hi guys i have been on and off the fourm for a few years now but recently back working and but hondas again its hard to shake the bug.
but as in the title i am hoping someone on here or mabe a few will be very generous
i am currently building 3 cars for people one supercharge ek , a b16b n/a eg6, and a b18c turbo eg4,
most of these cars are near complete, and are all running hondata s300v2 ecu
the Big problem i am having is getting someone to map them all my local tuners dont want to touch them as they have never mapped them before.
i do how ever have access to a dyno from one of the local guys to set the cars up myself. But i am new to the hondatas aswell so ....
what i would like to ask is if i list the specs of the cars below and a few of you guys on here running simaler set ups would you be generous enough to Private message the map ski file to me so i would have a real good if not perfect map to start with rather than using the hondata base maps which are not very good other than to get the car to start.. am not making money doing this as the 3 cars belong to good friends of mine.
I forgot to mention that i am from Northern Ireland.
the first car is a 97 ek4 vtis
engine is a b18c4 bottom end
b18c-r head and cams
10.5 compression
8psi jackson supercharger
4-1 headers 2.5 collector
2.5 inch header back exhaust
grams 550cc injectors
walbro 255 fuel pump.
think thats most of that one. There is water meth but not fitted yet.
second car is 94 eg6 sir
97 ek9 b16b engine stock head and internals
obx 48mm itbs
290cc injectors these my be changed for 440cc
4-1 header 2.5 inch collector
2.5 inch full exhaust system
Walbro 255 pump
this on work in progress as he keep change his mind
the 3rd is a 94 eg4 with b18c swap
Built head with option of gsr or type r cams
9.0.1 compression
walbro 255 pump
topmounted gt3037 turbo
38mm wastegate 8psi till run in
victor x intake 76mm tb
currently on dsm/evo 4 gsr yellow top injectors 510cc these will be changed for id1000 later in year
3"downpipe and 3"full exhaust system.
that the basic guys hope a few of you are kind and gernous enough to share your map with me.. these will not be shared and are for my own use only..
thanks for reading guys hope you can help.
Ps hondata fourm is useless for this stuff.
10.5 compression
obx 48mm itbs
Walbro 255 pump
9.0.1 compression
walbro 255 pump
even if someone has a very similar setup it doesnt mean the map will work the same for you. every setup is different.
Yep reposted in tuning.
yeh i know ever setup is defferant even if built from identical parts. But am hoping that it makes it easy to make fine adjustments then to suit that car rather than starting from bone stock.
There is one guy in the south of ireland 300 miles away and he wants over £500 uk pounds to set a base map not even start tuning.
Then its £350 per day to do the tuning.
Am getting a mustang 2wd dyno for a week and a guy to help me that sets up k-pro for for £150
Add half again on to those prices for dollars.
Dont know how that compares to the prices in the US
