04 Honda Crv motor problem
I have an 04 crv with a bad motor I got a k24a8 to put in it when installing the intake manifold I noticed the heads were different. Will the k24a8 work in the crv? And. If it will work what would I have to do to make it work.
Intake manifold is different, different throttle body setup as well. The a8 had electronic throttle instead the mechanical throttle cables I believe. I'm pretty sure the electronic throttle is ECU controlled. You should be able to slap on a throttle body and intake manifold from an 07-11 Element. As for the electronic throttle, you may need the Element ECU as well. I'm not 100% sure on this, hopefully someone here has done this swap and can help you a little better.
Duck Sauce
Nov 28, 2001 08:47 AM
