95 civic harnes tuck??
Old Jan 3, 2014 | 02:20 PM
jrsh0526's Avatar
Default 95 civic harnes tuck??
anybody have any advices when tucking main harness?
i just took of all the old tape tape and now i dnt know how to make it all go thru one hole
thanks in advance
Old Jan 3, 2014 | 02:24 PM
B_Swapped93's Avatar
Default Re: 95 civic harnes tuck??
you can't tuck the OEM harness really or if you do you'll be splicing it up and extending things aka hack job. Rywire tucked harnesses start at 400$ an come with all new connector's and wiring, well worth it I have on in my DC2.
Old Jan 3, 2014 | 09:32 PM
jrsh0526's Avatar
im on a low budget tho
Old Jan 3, 2014 | 09:42 PM
you can split the loom and run it threw the fenders etc I've never been a fan of that just cause it involves splicing. there's some DIY's etc on how to if you look around a bit.
Old Jan 3, 2014 | 09:52 PM
jrsh0526's Avatar
yea im searching see wat i find
Old Jan 3, 2014 | 10:26 PM
Marvin1985's Avatar
You can depin and fairly tuck an oem harness without cutting. I did but not to the max. Here it's all preference
Old Jan 4, 2014 | 01:27 AM
frost_white_ej1's Avatar
which car? year? model?
Old Jan 4, 2014 | 10:55 AM
jrsh0526's Avatar
Was it hard to depin everythung?
95 civic ex vtec
Old Jan 4, 2014 | 01:11 PM
if your doing a full tuck your going to have to cut and extend the 2 small harness that run on both side of the engine bay about 2 ft on each side no matter what, then tuck then inside the little hole that run through the engine bay chassis, either route the harness through the little hole that right next to the door harness or slit a hole in the door harness gromlet and pull it in that way, as for the part of the harness that connect to the engine harness, both can be pull through the fire wall you just have to find a way to take off the rubber gromlet i just cut mine and throw it away since I'm going to be buying a new one without the hole, then open up the back of the fuse box and unplug all the harness, that should pretty much be all of it (assuming you already unplug and disconnect all the rest) that will then let you pull the harness inside the cabin without de pining the main harness (i got to warn you it take a bit or work and effort to pull it through but save you the headache of re pining all the wire) as for cutting the two small harness just make sure you leave yourself enough room to work with all the wire from them harness are color coded except for a few (about 4 wire that are the same) i just make sure to tape it and mark it off so i know which one it which.
Old Jan 4, 2014 | 02:42 PM
jrsh0526's Avatar
Headlight harness is tucked already...the one im.having trouble with with engine harness....I going go to put it thru the heater core hole
dc4teg95
Jul 13, 2010 02:54 PM
jrp355
Jun 23, 2009 08:11 PM
Prelude2DaWorld
Mar 12, 2004 11:07 AM
