built h22 knocking
I recently bought a semi built h22 that the previous owner said it had a rod knock, during the tear down the mains and rod journals looks to be normal but further inspection of the head I see that under the vtec (middle) rockers has been grinded down along with the LMA, is this because of a tight valve adjustment or the cams are too big?
Specs on motor:
H22a
Mahle 11.5 pistons
Eagle rods
Blox b cams
Blox valve springs
What looks to be k20 retainers
Skunk2 pro cam gears
Ported head.
Here are some crappy phone pics I took of the valve train.
Could this be why the previous owner thought it was a rod bearing?
Specs on motor:
H22a
Mahle 11.5 pistons
Eagle rods
Blox b cams
Blox valve springs
Ported head.
Hmm. If the LMAs are hitting the rockers then it's possible you have B VTEC LMAs and not H22. Only way to confirm or deny this theory is to measure a B series LMA and compare to what's installed in the head.
H22 are shorter than B series.
Correct. Which is why if a B series LMA was used in a H22 there would be clearance issues. Have you taken the LMA's out of the head and measured / compared to a known H22 and B series LMA? That would eliminate the guess work all together.
