good plugs for cooling system bypass
Old Jan 2, 2014 | 04:37 PM
carlos8's Avatar
Default good plugs for cooling system bypass
hi guys, I recently change my throttle and intake and for cosmetic, I remove the looped hose from the little nipple on the thermostat housing to the intake and put plugs.
In two weeks one exploded like 6 days after put it and the other today. I've seen this made a lot of times. But you guys that made that before use any special material or just standard auto parts bypass plugs?
Old Jan 2, 2014 | 04:43 PM
B_Swapped93's Avatar
Default Re: good plugs for cooling system bypass
Pics of said hoses ? not following your description.
Old Jan 2, 2014 | 04:51 PM
carlos8's Avatar
The little nipple in yellow and the intake manifold have another equal.
https://honda-tech.com/attachment.ph...1&d=1388713813
Those nipples are 5/16 hard to find this caps.
Old Jan 2, 2014 | 05:04 PM
I'd just put it back, it's such a small out of the way hose but I suppose you could drain all the coolant pinch it then weld the end...
Old Jan 2, 2014 | 05:15 PM
carlos8's Avatar
Yeah, I going to put the looped hose again for now!! I just put this thing together 2 weeks ago.
In the future I going to cut them tap and put s/s plugs.
trav
Dec 9, 2013 05:28 PM
johndoughy
Jan 1, 2009 04:22 PM
vinuneuro
Jun 4, 2007 09:03 PM
crizkeeth
Nov 21, 2004 08:18 AM
