93 honda accord sputters on acceleration
Old Jan 2, 2014 | 04:03 PM
jcook3890's Avatar
Default 93 honda accord sputters on acceleration
ok my 93 honda accord automatic transmission after the car is warmed up will sputter real bad in order for me to drive in stop and go traffic or at traffic lights i must shift the car as if it were a manual otherwise it will stall.
i have replaced:
distributer
fuel filter
fuel pump
fuel pressure regulator
and all 4 injectors
another addition once warm it wants to idle real low around 500-600rpm gota give gas to keep from stalling
Old Jan 2, 2014 | 05:07 PM
afnan's Avatar
Default Re: 93 honda accord sputters on acceleration
Don't just keep throwing parts at find the bad ones and then only replace them. When was it last time tuned? Throttle body etc try testing spark plug wires. Take timing gun to verify the timing
Old Jan 2, 2014 | 08:24 PM
brakedrum's Avatar
Has the oxygen sensor ever been replaced? A bad one or a failing one will cause sputtering and lurching--making the vehicle barely driveable--and it won't always place a code in the computer to make the check engine light come on. Just one possibility.
Old Jan 2, 2014 | 08:40 PM
holmesnmanny's Avatar
Also, check for any and all check engine codes.
Old Jan 3, 2014 | 12:06 PM
jcook3890's Avatar
how i check codes on obd1 i know u can cross the terminals on the test plug and it will flash on u but with out the light bein on when u do that it just puts the light on solid
Old Jan 3, 2014 | 02:09 PM
jcook3890's Avatar
timings good and i tested old fuel pump and it failed wouldnt start at all before i replaced and the distributer threw code 4 that.
just put o2 sensor on still studderin bad but i can now go from a stop in 3rd gear as apposed to 1st cat mabye?
jmali001
Jan 2, 2017 10:20 AM
TrevvTurnt23
Apr 29, 2015 10:07 AM
bdr_one
Dec 20, 2014 11:56 AM
huntozmer
Sep 15, 2014 09:24 AM
istabrak
Oct 28, 2009 01:14 PM
