07 crv sway bar options/ performance options
Are there any after market sway bar options?
I'm not too fond of the stock handling or the fact I can feel every bump in the road. My wheel alignment checks out fine.I have 07 acura tl wheels 17 x 8 with 235/60 tires and I'm not fond of the steering feel at all.
Also any racing header, pulley set, or CAI options from other Hondas that can work on an 07?
Get a luxury suv?
A rear sway bar won't do much good for your handling. You will have slightly less body roll, but a crv is a crv. It will require a lot more work if you want it to handle better. Full coilovers would probably make more sense.
Also, if you are on stock suspension and the ride is too bumpy then your best bet is definitely getting a different car. Most of the aftermarket suspension stuff usually makes the ride stiffer.
You can try getting 15/16" wheels with taller sidewall tires - it'll soften the ride a bit.
Engine performance related - not sure. Find someone in the area with a similar year civic and see if anything fits?
sorry can't help much with that. Free bump.
Donavan Meyers
Nov 5, 2018 01:46 PM
